Swap Help
Swap Help
OK ive tried to ask this question on another forum but no one answered me so i thought id give you guys a try. ..... i want to drop in a B18C (GSR) into my newly aquired '95 Del Sol Si (D16Z6) ... I thought that i would be able to just drop in the GSR motor with out doing anything to the motor mounts but the other forum said that i do but thats as far as they got they just stopped telling me stuff so ima try and see if you guys can help me.... here are the questions that i am asking..........
#1. Do i need to change the motor mounts?
#2. What kind of mounts do i need to switch to if i must?
#3. Where can i find the new motor mounts (if needed) (website would be nice)?
#4. Will i have to weld these on or are they bolt on mounts?
#5. Has anyone performed this swap that can tell me how to do it correctly and what to watch out for or if you can gimmie a link to a site that tells me how that will work too?
#6. What other parts will i need to make this swap complete?
Thanx in advance...... i hope lol
Moderator
Re: Swap Help (95SolSi)
first off....USE THE SEARCH FUNCTION!!!!!!!!!!!
now since i'm in a good mood i'll help you....
no all your mounts will work!!!
see the above
see #1
see #1
direct bolt in swap....you'll need some parts....this is all i'll give you...you can use the search function
see #5 search function
you are welcome
see the above
see #1
see #1
you are welcome
ur mounts will work i think u need a rear b18 bracket though.. someone has told me i have a b18b same thing as far as all that goes. everything should work but i highly suggest that u buy a poly driverside engine mount becuz with the torque and everything they break like 1 a week with the stock mounts.
