sup with my dash lights????
hey I got a 95 hatch and the only lights on my dash that work are are the ones on the cluster. If no heater or Ac is on and no buttons are pressed, the all is off. So basically when I press the ac button and so it blows toward my feet, only those little lights(green) are on. Since its all off, I cant see which button is for my feet or face or for the dash.
I checked the fuse cover if it has a fuse for that but I think my fuse cover is different from the fuses I have in there now.BTW I have a 95 gsr in my hatch(if that helps you in any way).
When your driving at night, are the ac/heater buttons supposed to be bright lit?
it should be like in the picture but its not
Re: sup with my dash lights????
a quick search https://honda-tech.com/forums/showth...limate+control
i'll check it out but thanks bro
This is a pretty common problem with these cars but the bulbs are prob fine. It is more likely a bad solder joint/connection in the unit its self. My car will have all the lights on in the climate control then if you press a button half of them will go out.
I hope that's not the problem haha
well I'm not even sure I just realized this couple days agoso one of these days i'll check it out
VTECtravler
13
10-04-2006 07:51 AM
