SUN ROOF WON'T close!!!!
my sun roof on my EG won't close
I've check the fuses...nuttin blown!!!
what can it be a blown sun roof motor???
well is there a way I can manually close it back????
is this expensive to relace and fix????
HELP....my civic Nation people...!!!
Re: SUN ROOF WON'T close!!!! (EG6[B16A1])
ahhh...you and almost every si owner
try wd40? give it a push as your closing it
mine doesnt close unless i hlep it...
honda sunroofs
honda sunroofs
Re: SUN ROOF WON'T close!!!! (krazySOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC »</TD></TR><TR><TD CLASS="quote">ahhh...you and almost every si owner
honda sunroofs </TD></TR></TABLE>
I never had a problem with my old Si's sunroof.
on the center of the headliner, toward the back of the car (ie above the back seat) ther should be a plastic "plug" that you can unscrew and manually crank it closed (the crank should be in with the tire jack) hope that works!
nick
nick
Re: SUN ROOF WON'T close!!!! (92h22a)
There should be a tool that is in with the lug wrenches to manually close the sunroof. Make sure it is greased very well. Which I have to do since it is stuttering when opening.
Re: SUN ROOF WON'T close!!!! (Sivicfied)
haha mine dont close or open unless i push it up with my hand while pressing the button at the same time =/ ......but the tool to close it comes with the spare tire tools.... u pop the button out (its a small circle with a line through it) by turning the circle so the horizontal line is verticle or vise versa .....its located between the rear view mirror and the moon roof itself.... after u get the button/cover out stick the tool in there and just crank it
Re: SUN ROOF WON'T close!!!! (specialTEG)
i figured my problem!!!!
it was not the fuse for the sun roof, it was the fuse for my wipers
I don't understand why this fuse went out instead of the sun roof fuse
well is this normal to blow fuses??? or do I have a bad connection somewhere????
CIVIC NATION
CIVIC NATION
