Stut bar question
Old 11-17-2002, 04:24 PM
AcuraEL's Avatar
Default Stut bar question
Hello.
I have this question.
I got an AcuraEL (Canadian 4 door civic)
so the rear dash cracks every time I go over some bumps or enter a parking or something. I think Civic should have the same problem??
So, this is because the body gets twisted, right?
So, if I'd put a Strut bar (torsion bar, whatever) would it help?
Thanks a lot!
Old 11-17-2002, 04:27 PM
VTEC-DA's Avatar
Default Re: Stut bar question (AcuraEL)
What do you mean by "the rear dash cracks"? Do you mean the rear of the car squeaks? If so, that could be any number of things. I wouldnt look at a rear strut bar first.
Old 11-17-2002, 04:30 PM
AcuraEL's Avatar
Default Re: Stut bar question (non-turbo2dr)
I think it's called Rear Tray or something, it's where the two speakers are.
Look at the link, it's the part # 1
http://www.hondaautomotiveparts.com/...ARNISH+%281%29
Old 11-17-2002, 05:32 PM
Solbros Owns Me
Evs-One's Avatar
it's probably loose, look and see if you're missing any screws, or just press on it and see where it is weak
Old 11-18-2002, 11:56 AM
AcuraEL's Avatar
Default Re: Stut bar question (Emerica)
I'm sure nothing is loose.
I think I,t because the body twists and my car is lowered so this doesn,t help.
I justed wanted to know if installing a rear strut bar would solidify the body...
Old 11-18-2002, 12:29 PM
b00stn's Avatar
The rear strut bar will help make things more solid but I doubt it will make the rear deck stop rattling. This is a pretty common problem on civics. Just get in there and start checking for rattles.
Old 11-18-2002, 01:13 PM
AcuraEL's Avatar
Default Re: Stut bar question (b00stn)
ok, but it doesN,t ratlle, it's more like a door hinge that squeaks every time I go slowly over a bump
Old 11-18-2002, 07:06 PM
OE Tuner's Avatar
This is real typical. I had a few friends with 99-00 Si's that had the same creak coming from the drivers side rear tray. It is the body creaking at the joint between the rear shelf and the rear inner panel.. Not much you can do. A rear tie bar might help a little. You could have it welded in better, but that might be a bit crazy.
Old 11-18-2002, 07:30 PM
Ganew's Avatar
Default Re: Stut bar question (OE Tuner)
Instead of welding you could try a seam sealer which you can get at any autosupply store for pretty cheap. Just squirt it in with a caulk gun. Good Luck!!
Old 11-18-2002, 07:35 PM
shawnhayes's Avatar
Thanks a lot!
I have the same problem, and it got TONS worse when I tightened up the rear with polyurethane bushings, rear sway bar, and rear lower tie bar.
It doesn't hurt the car, just that the flex joints (where the flexible goo is) are flexing to their max.
Shawn
Old 11-19-2002, 12:47 PM
AcuraEL's Avatar
Default Re: Stut bar question (shawnhayes)
Thanks guys.
You were helpful!
jdmeg9
10-06-2005 03:20 AM
DocJP
10-29-2004 11:46 AM
Keyed ITR
04-06-2002 11:28 AM
Quick Reply: Stut bar question
