Stumped in regards to retaining my A/C
I recently purchased a jdm D15B for my 1994 honda civic CX. Well, summer is here and i'm DEFINATELY going to keep my AC installed, however, where do i disconnect it from off of my old long block? Isn't it pressurized and dangerous to play with? I'm just wondering because i don't want to be stuck on this when i do my swap. So ultimately, i'm just looking for some help on removing my A/C and retaining it for my new swap, i don't want to disconnect some hose that's going to leak out all the refrigerant. Any help or links to threads will help!
P.S. I've BEEN searching for this.
- thanx
- thanx
Re: Stumped in regards to retaining my A/C (0ptimus Prime)
undo the compressor from its mounting bracket and just move the compressor aside.
4 12mm bolts holding it to the bracket then easiest thing to do is tie it to the radiator support so its out of the when when you pull your motor.
Re: Stumped in regards to retaining my A/C (90crxzcgasd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzcgasd »</TD></TR><TR><TD CLASS="quote">undo the compressor from its mounting bracket and just move the compressor aside.
4 12mm bolts holding it to the bracket then easiest thing to do is tie it to the radiator support so its out of the when when you pull your motor.</TD></TR></TABLE>
^^^ What he said. And if you're worried about it leaking or being pressurized (which I honestly don't know) You can have the system evacuated. I've heard some places do it for free, but it cost me $25 at a local shop.
As long as you're leaving all the lines connected, you should be fine.
Re: Stumped in regards to retaining my A/C (Aber)
as they said, take it off the motor and zip tie it somewhere. since a pic is worth a million words....you can see it standing up near my driver side corner light.
One more question, do i need to detatch the compressor from any pulleys or belts? Or is it strictly a bolt off and move out of the way process?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime »</TD></TR><TR><TD CLASS="quote">how do you remove that belt?</TD></TR></TABLE>
You're going to swap in a motor, but you don't know how to loosen the A/C pulley?
It's self explanatory, go look at your motor. (hint: theres a bolt holding the pulley onto the compressor bracket.)
eric.
08-18-2005 06:15 PM
civicracer1993
27
06-28-2002 07:58 AM
slowpokesi
15
05-21-2002 04:52 AM
