stud problems...
Old Jun 17, 2008 | 09:59 AM
16yroldekownr's Avatar
Default stud problems...
i have a d16y7 was trying to remove my header. i put WD-40 on them before i started to remove them..one stud is just spinning when i go to turn the nut off and one stud broke....not sure what to do ...
Old Jun 17, 2008 | 11:20 AM
Default Re: stud problems... (16yroldekownr)
i know, someone knows something to do. please help me.
Old Jun 17, 2008 | 11:26 AM
pdiggitydogg's Avatar
The one that spins, cut the nut off.
The one thats snapped, replace with a bolt of proper length.
For the one that spins, if its the entire stud that spins, cut it close to the head, drill it out with a 6mm bit, and then use a helicoil kit to repair it to original thread pitch. Buy the entire kit, with the right tap. IF you dont feel like you can do this, go to a shop.
If its just the nut that spins, just grab the stud with vice grips, remove it and replace.
WD40 is not really a penetrating solvent, its more of a cleaner and general lube. Use PB Blaster instead...
Old Jun 17, 2008 | 11:30 AM
Default Re: (pdiggitydogg)
do you know a good place i should look to get new studs? and i'm not to sure on how to replace them.
Old Jun 17, 2008 | 11:32 AM
They spin into the holes just like bolts do, but you have to use 2 nuts to thread them (use one nut to lock against the other)
And you can get studs at the hardware store (NOT home depot...go to ACE or similar). There, if you dont get what I mean by locking the nuts, someone will be competent enough to show you.
Oh, and take the damaged stud with you for size. I know the size off hand, but you learning is better.
Old Jun 17, 2008 | 11:49 AM
i know what you mean by locking the nuts. thanks i was worried as hell.
Old Jun 17, 2008 | 12:00 PM
hey um..one more quick noob question?
i havent got the chance to get the car on jack stands to fully remove my header, but would i have to take apart the motor at all or anything like that to replace the studs?
Old Jun 17, 2008 | 06:09 PM
The studs sit right in the front of the head...so...no you dont have to do anything extra.
Atauto
Honda CR-V & Element
May 27, 2015 04:19 AM
ToTriggerHappy
Feb 19, 2010 06:33 AM
blaze the chemi
Jul 26, 2007 08:20 AM
the.hamburglar
Jul 23, 2005 09:44 PM
OTT
Mar 1, 2004 11:11 AM
