stripped oil drain plug
Old 07-15-2007, 06:44 PM
  #26
Crx Jimmy's Avatar
Default Re: (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">
I would just get one of these, Its called a piggyback drain plug, you can get it in an oversize so it will cut new threads and seal properly, when you have to change the oil you just remove the smaller plug inside
Old 07-15-2007, 06:45 PM
  #27
Doostur's Avatar
Be safe than sorry... but a new pan sir!
Old 07-16-2007, 05:53 AM
  #28
Leb_CRX's Avatar
Default Re: (oneludesol)
awesome, i'll keep this in mind if the drain plug idea doesn't work like I want
or might pick it up just for ***** and giggles
Old 07-16-2007, 06:57 AM
  #29
Go Tigers!
Bense's Avatar
put JB weld on the stock drain plug and lock it into place. Then weld one of these on
https://honda-tech.com/zerothread/2008473
Old 07-16-2007, 07:14 AM
  #30
Global Moderator
tech8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">put JB weld on the stock drain plug and lock it into place. Then weld one of these on
https://honda-tech.com/zerothread/2008473</TD></TR></TABLE>
Bense,
That's pretty neat. Here an idea, what about welding that over the original drain hole area, then he don't have to re-drill?
Old 07-16-2007, 08:53 AM
  #31
b20vteclsintegra's Avatar
u could just tap and die it. they make kits for that and it would only take like 15 to 20 min and u will be done with it. and it would be good as new.
Old 07-16-2007, 10:16 AM
  #32
Leb_CRX's Avatar
Default Re: (b20vteclsintegra)
I was told by several people that the oil pan's too thin to be tapped and die'd
no idea, but thanks for the suggestions guys, I'll try the fram solution first, followed by the welding hte nut shut and using the oil extractor and go from there
HT rocks as always
Old 07-16-2007, 10:38 AM
  #33
Syndacate's Avatar
Default Re: (Leb_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leb_CRX &raquo;</TD></TR><TR><TD CLASS="quote">what are they called? the things that suck oil through the dipstick
I've heard of them, and I know VW's use them...but for the life of me can't find a link online to buy it...and no one locally has a clue</TD></TR></TABLE>
Iono about that one chief, I have a '00 MKIV Jetta and it's got a regular 'ol drain plug which works 100%.
Old 07-16-2007, 12:15 PM
  #34
sageuvagony's Avatar
Those suredrain hose thingie take forever to empty out your oil.. Mine is sitting in my shed somewhere.
Old 07-16-2007, 05:32 PM
  #35
Leb_CRX's Avatar
Default Re: (Syndacate)
I know the new TDI's use it
might just be the diesel's, but I have a buddy with a 00 and another with an 06 and they both use that
Old 07-16-2007, 05:34 PM
  #36
Leb_CRX's Avatar
Default Re: (sageuvagony)
wanna make some $?
PM me
1drivinmofo
03-10-2010 05:16 PM
1EGdude
01-18-2007 04:51 PM
mitch3814
04-05-2005 06:37 PM
SpeedMonkeyRacing
08-07-2003 07:07 AM
92preludeSI
03-10-2003 07:33 PM
Quick Reply: stripped oil drain plug
