Stock SI V-Tec 1/4 mile times
I previously posted about a friend (if you want to call him that) who said he had a J-spec engine, which turned out to be false. Well, now he is telling me that his Del Sol does 0-60mph in 5.0 seconds flat with his 300lbs fat *** stock, no mods whatsoever. He also claims he ran a 15.1 and that his car weighs 2100lbs. Through some research I found out the truth, presented it to him, but he just called me a hater due to my love with rotaries. He only accepts things said from here, so if you could provide me with the stock information I would be greatly thankful. Thanks.
Guest
Posts: n/a
Re: Stock SI V-Tec 1/4 mile times (h0nduhsRgay)
Since when does a delSol weigh 2100 lbs? Those things are tanks!!
I've seen delSol VTEC's (DOHC) run low 14's, but with hella mods on it.
In stock trim, they should run mid to high 15's with a good driver.
Location: somewhere between the motor and tranny, putting power to the wheels...
Re: Stock SI V-Tec 1/4 mile times (B18C-EJ1)
my stock 95 coupe ran a 15.3 and arent the del sols hella heaveir than mine? im thinkin your "friend" is bullshittin...
This name was created in only a way to attempt to deface my "friend" (biggest bull ******* in the world) and has no bad intention of meaning to other honda drivers out there. I like honda's very much. My friend is running a 94 HB with a B18C5 with a T4 at 10 psi of boost and hitting high 12's in the 1/4. I wouldn't mind dropping my 13B-REW into a HB ....
Re: Stock SI V-Tec 1/4 mile times (CleanSi)
I ran a 15.2 90mph at IRP Import Drags in my 92 civic dx hatch with a 93 sohc vtec motor/tranny/ecu. Only had short intake, header, and canister muffler w stock dx piping. Full interior, A/C, street tires, driven 4 hours to the track on a 90 degree day. Drove the car 2 days to florida on vacation, ran at speedworld with the trunk full of stuff and ran a 15.4.
93 VTEC
04-28-2002 05:19 PM
