Still has hesitation..
Okay guys, I just finished installing a brand new Synchrotech vx Trans for my civic vx hatch. It now has a brand new flywheel, clutch, and transmission. I don't know where it is coming from and need some help to further diagnose.
Hesitation is in all gears and I have pretty much ruled out those parts I replaced. Also all motor mounts are good I checked them all. Next on my list is to check the dizzy. Probably just gonna go buy a new one, slap it on and see what happens.
The Grumpiest
Re: Still has hesitation..
What? How do you figure the transmission caused the hesitation? And you've been dealing with issue since last July?
Have you done ANYTHING anyone has suggested in the near year you've been posting about this problem?
Lol it just had so many problems that it has taken a while to sort them all out. Transmission replacement wasnt to fix hesitation, it was to replace the old ****ed one that had horrible screaming gears
On another note, put in a new dizzy and acceleration is perfect now no hesitation at all!
Do you have a CEL? And Cluch/Flywheel/Transmission will not cause hesitation. Fouled Plugs, Bad Fuel Pump, Clogged Fuel Filter, Improper Timing, Bad Sensor. All these things can cause hesitation.
AZNBIGPIMPN505
01-07-2005 11:42 AM
