Steering wheel twitches violentley :(
Old 08-23-2006, 10:26 AM
Ex Member's Avatar
Default Steering wheel twitches violentley :(
I all of the sudden got horrible vibration @ any speed and my steering wheel twitches violentley from side to side. I dont know if its the axle, mounts or wheel bearing. What would you think it is? I would post a video but I dont know how to upload avi. files.
Old 08-23-2006, 10:29 AM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: Steering wheel twitches violentley :( (Turblow*)
does it do it on the gas and stop off the gas?
does it do it on the brakes?
does it do it at highway speeds?
what mph does it do it at and does it stop after a certain mph?
Old 08-23-2006, 10:48 AM
Ex Member's Avatar
Default Re: Steering wheel twitches violentley :( (boostedcivicsir)
on the brakes it decreases slightly and very noticable.
Old 08-23-2006, 10:55 AM
WickedHonda00's Avatar
Typically, tires will make a car twitch if they need to be rotated/balanced or just replaced all together. If it does this when braking, you'll need to look at the rotors, they probably need regular maintenance. Or you could actually be unlucky enough to have issues with your axles or bearings, which would suck. I don't think a mount would be the problem, as it would be obvious if the mount was broken. They typically make loud cluttering sounds, especially after each shift, and usually a little power is lost to the wheels.
Old 08-23-2006, 11:01 AM
juevi (old)'s Avatar
A tire will cause some twitching but a "violent" twitching may be an axle issue. I get it in the air and check things out.
Old 08-23-2006, 11:28 AM
EGwhat!!!'s Avatar
Default Re: Steering wheel twitches violentley :( (JJDrivesAJazz)
steering rack?? possibly a loose bolt or missing bolt..
Old 08-24-2006, 10:47 AM
Ex Member's Avatar
Default Re: Steering wheel twitches violentley :( (EGwhat!!!)
Im going to check it out this weekend since I dont have time on the weekdays.
Old 08-24-2006, 12:02 PM
dAng!
Russ713's Avatar
I'll be money it's the tie rod ends. Replace them because most likely one of them has a bad ball joint.
Old 08-24-2006, 12:08 PM
Mr. Indecisive
EJ8VTEC's Avatar
kobe ftw!!
i would say check the axles
Old 08-27-2006, 02:45 PM
Ex Member's Avatar
Default Re: Steering wheel twitches violentley :( (EJ8VTEC)
I found out what it was. It seems I had a huge ball on tire. It was swollen and it was only in one place. WTF ?
Old 08-27-2006, 03:15 PM
Ek Forever y0!
Libertariat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turblow* &raquo;</TD></TR><TR><TD CLASS="quote">I found out what it was. It seems I had a huge ball on tire. It was swollen and it was only in one place. WTF ?</TD></TR></TABLE>
New tires time.
Old 08-27-2006, 03:35 PM
Rock Meathammer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turblow* &raquo;</TD></TR><TR><TD CLASS="quote"> It was swollen and it was only in one place. WTF ?</TD></TR></TABLE>
Tire seperation, very common. Get new ones before it blows out.
Old 08-27-2006, 08:31 PM
Ex Member's Avatar
Default Re: Steering wheel twitches violentley :( (B20 EJ6)
I actually drove on this tire for like a whole day because my other car did not want to start. Kinda scary.
Ohbebe75
10-24-2015 07:50 AM
thebluecrx
12-15-2010 11:50 AM
ElZRex
27
03-21-2006 09:00 AM
yOnKiNaToR
09-01-2005 06:46 PM
Toda Party
10-27-2002 07:26 AM
Quick Reply: Steering wheel twitches violentley :(
