Steering wheel installation - question!!!
Do not purchase anything from me. -HT Staff
i dont see y not... if its like all the other honda steering wheels where the center/airbag comes off and theres a 19mm nut holding the steering wheel on... then there shouldnt be a problem...
Re: Steering wheel installation - question!!! (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">What is the point of this post?</TD></TR></TABLE>
The point of this post is to ASK IF IT CAN BE INSTALLED ON 96-00 Civic...
And if you take your head out of your ***, you will see the question under the picture in the first post...
Re: (THC_H22 PROJECT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC_H22 PROJECT »</TD></TR><TR><TD CLASS="quote">i dont see y not... if its like all the other honda steering wheels where the center/airbag comes off and theres a 19mm nut holding the steering wheel on... then there shouldnt be a problem...</TD></TR></TABLE>
Is the "hub pattern" the same size like in the Civic?
Re: (KKVTi)
that is a good question
tech advice
tech advice
HT Order of Merit
Re: (clint g)
**** you dude. Don't go E-thuggin on me. You didn't even say what kinda car that is out of. You wanna talk ****, pm me, and I'll give you my phone number.
/yourself
What kind of car is that pic from? The hub patterns need to be similar. That steering wheel looks similar to the S2K steering wheel, so im sure its possible.
Modified by JDM_Ej at 1:20 AM 8/29/2005
/yourself
Re: (JDM_Ej)
Hey man, that was meant like a joke... and if you want to take it to the serious side, let's go...
Why did you make sucha stupid comment??? Why didn't you ask at the first place about the car that it is from?
It is from Honda Insight...
Re: (KKVTi)
To answer your initial question, yes it does work and bolt on as I have one on my 97 civic. Please be smart and disconnect the battery for at least 20 min so you dont get an airbag in your grill. Everything else is a bolt on affair.
Re: (perlmeistere81)
the EK can use s2000 and rsx/ep si steering wheels. i recall there was a tiny bit of wiring work. someone did a write up on it. i'm too lazy to search for you right now
Re: Steering wheel installation - question!!! (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi »</TD></TR><TR><TD CLASS="quote">Hi!
I just came accross this steering wheel and I think it is the best looking Honda steering wheel ever...
My question is: can it be installed on 96-00 Civic without any major modifications?</TD></TR></TABLE>
that is the sweetes gauge cluster ive ever seen i wonder if that would go into a 91 crx?
what do you guys think?
Re: (spoon.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg »</TD></TR><TR><TD CLASS="quote">Sorta kinda looks like a S2K wheel.</TD></TR></TABLE>
the insight wheel i just like the s2k, minus leather
Multi-paradigm
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">**** you dude. Don't go E-thuggin on me. You didn't even say what kinda car that is out of. You wanna talk ****, pm me, and I'll give you my phone number.
/yourself
Panties in a twist for no reason.
Your first post was ignorant, and KKVTi simply called you on it. Settle down.
And don't go calling people "E-Thugs" and then offer to phone-fight in the same paragraph. Bottom line is, you don't know him and he doesn't know you. Quit trying to escalate the situation. E-thugs, Phone-thugs = same ****.
Anyway, yes that's a good steering wheel. I wouldn't definitely go for it. No major modifications required.
/yourself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeistere81 »</TD></TR><TR><TD CLASS="quote">Please be smart and disconnect the battery for at least 20 min so you dont get an airbag in your grill. Everything else is a bolt on affair.</TD></TR></TABLE>
Re: (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi »</TD></TR><TR><TD CLASS="quote">Hey man, that was meant like a joke... and if you want to take it to the serious side, let's go...
It is from Honda Insight... </TD></TR></TABLE>
Both of you guys, shut the **** up, right or wrong. Chill.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeistere81 »</TD></TR><TR><TD CLASS="quote">To answer your initial question, yes it does work and bolt on as I have one on my 97 civic. Please be smart and disconnect the battery for at least 20 min so you dont get an airbag in your grill. Everything else is a bolt on affair.</TD></TR></TABLE>
Thanx man... that's all I wanted to know
And thanx about the battery-issue comment
there is a disable switch for the airbag.. if u look behind the steering wheel there is a little compartment that has a screw.. unscrew it and pop it out.. there should be this red thing in there that goes onto the airbag plug.. that should keep it from going off
Re: (KKVTi)
And thanx about the battery-issue comment</TD></TR></TABLE>
Multi-paradigm
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">My apologies for the earlier comment. I was having a really bad day.
Good luck with the steering wheel. </TD></TR></TABLE>
**** happens. Hope things are better for you.
HT Order of Merit
Re: (Screwtape:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape: »</TD></TR><TR><TD CLASS="quote">
**** happens. Hope things are better for you.</TD></TR></TABLE>
Thanks.
Women. Can't live with em, can't shoot em in the face.
Thanks.
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Thanks.
Women. Can't live with em, can't shoot em in the face. </TD></TR></TABLE>
But you can buy them a new vacuum cleaner to make them busy cos I came to the conclusion that the more time women have, the bigger pain in the *** they are... just keep her busy and your safe
