Starter Problems!?
Starter Problems!?
ok..i just replaced my starter with a new one from Pep Boys...installation was pretty straight forward...but when i go try to start the car it wouldn't even start!...i would hear some sparks but that's all...could the starter be bad?..is there a way to check if the starter is defective? TIA.
Re: Starter Problems!? (agent marlon)
usually when people replace starters or do engine swaps they almost always forget the little tiny spade plug that goes on the starter.... check that i have seen that happen a lot. alsi check for sorrosion around the starter and clean the connections really well.
Re: Starter Problems!? (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">usually when people replace starters or do engine swaps they almost always forget the little tiny spade plug that goes on the starter.... check that i have seen that happen a lot. alsi check for sorrosion around the starter and clean the connections really well.</TD></TR></TABLE>
thanks..ill go check that out
TiffanyJJ08
10-03-2005 12:35 PM
