SRS won't reset
SRS won't reset
Hi.
It seems like after I tossed the steering column last time to get new pedal assemble installed, the SRS came on, I tried to reset it two times, resets were succesful but it would come on again.
I messed it up, right? So, what are my options now? Bring it to Acura and pay $$$ to get it fixed?
I checked the wires, and the looked fine, kinda.
Re: SRS won't reset (AcuraEL)
I am pretty sure that if your SRS light comes on then it stays on. This is because it is a safety device, therefore it MUST be attended and cleared accordingly. Bring your car to a shop locally and they can clear the code for you, do this as soon as possible, your SRS may not be functioning properly.......HTH
By the way the MOST they will charge you is an hour which in some cases is as cheap as 30 bucks.
Re: SRS won't reset (4g4me)
thanks for reply, but as I said, i DID clear the SRS memory properly, it blinked two times at the end, meaning that it was done. What I have is some major problem, I messed something up basically, cut some wire or something like that.
