Squeaky Clutch
Squeaky Clutch
The actual clutch pedal on my car squeaks when I push it down, its just annoying. Is there a way to maybe grease it up so it wont make that noise any more?
Re: Squeaky Clutch (crxricer66)
Yeah, ill do that. Would just WD-40 basic grease work? Its not that its a bad clutch pedal, its just annoying lol.
Re: Squeaky Clutch (sleeper_civic_4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper_civic_4dr »</TD></TR><TR><TD CLASS="quote">Clutchbearning, part is about $50 labor is huge since you have to pull the trany
</TD></TR></TABLE>ya it's not coming from the tranny, in my case anyways, it's either from the pedal assembly or the clutch cylinder, not the tranny tho for sure.
Re: Squeaky Clutch (rleonekc)
dude my hatch does the samething!!!! and its freaking annoying!!!! and embarrassing!!!
I sounds like it is coming from the pedal!!!
Im going to try and grease it down....
ill let u guys know if anything happens!!!
Re: Squeaky Clutch (jdmjin)
I took my whole pedal out, wiped it down, put graphite and bearing grease in the pedal assembly and did the same on the inside of the rubber boot on the master CYL and mine still squeaks.
My next step if to apply turbine grease in those same areas. If that dosent work then im buying a new one
look to see if your clutch fluid resivour is low if it is look at your pedal and see if the clutch master cylinder is leaking if it is that means it is blown and it needs to be replaced if that doesnt fix the problem then at least you replaced a failed part. :-) mine squeaks as wel and my master cylinder is bad I just havent had time to replace it yet
Re: (Unit44justin)
my clutch pedal master cylinder has a slight bit of fluid coming out of it inside the car. its not leaking but the rod that goes in and out is wet with fluid. it doesnt squeak though. any of you guys see this before?
there was thread awhile back most of the time it the clutch fork where the master cylinder is where ti meets with the tranny just use some *** lube on it and it will normally fix the problem here i found it
https://honda-tech.com/zerothread?id=179021
Re: (ejoner)
Sorry to bring this thread back from the dead but when I press my clutch I hear it squeak from the bottom left corner of the engine bay (when you are sitting in the drivers seat)
