Sqeaky coming from clutch
I have a 93 del sol S.. stock with a d15. Within the past 4 months I've had a new clutch, master brake cylinder and CV axle. The shop I use for my repairs is very thorough on there repairs. Sense all these repairs, (All done at once) I've noticed a quiet but noticeable squeaky sound when I left off the clutch in any gear, at anytime.. But AS SOON as I touch the clutch when slightly the sound completely goes away and as if it never existed.. I read the squeaky clutch thread, Would this pertain to my issue or could this be something more major?
Thank you in advance.
Re: Sqeaky coming from clutch
very simple, pilot bearing controls the movement of the input shaft, most mechanic shops wont ever change them, i've dealt with over 20 different cases on whining/squeaking noises.
input shaft movement only happens when letting off because when pushing in your pulling it out, when your letting off your pushing in.
basically your 'well known/good' mechanic shop probably only changed your clutch disk, not your pressure plate, throw out bearing, or pilot bearing..
pilot bearings make noise when letting off
throwout bearings make noise when pushing in
In my opinion yes it should be but like i said most shops won't touch them unless the bearings are falling out.
in shops eyes when you say clutch job it has a single meaning cheapest way in and out.
now given clutch disks are usually $80-120 themselves but if you get a clutch kit, it includes disk, pressure plate, throw out bearing and pilot bearing.
if someone brought me a car and said clutch needs replaced, I'm grabbing a clutch kit, and brakr fluid to flush out the hydro lines. and make sure the slave/master cylinder is working properly
I'm no shop but i usually charge $100 per pull, $100 in $100 out, if it takes me half a day your bill in labor is $250-$275
All day $350
But being shops are pretty much charging $60+ an hr I'm sure $400 is about right.
but in my opinion if I'm paying over $400 for a clutch job they better damn well change all that.
All day $350
OP, my Civic started doing this just after I purchased it. You have two options. Replace your transmission or have it rebuilt. Either option has advantages and disadvantages. Mainly cost and risk. You could pick up a used transmission cheap. I've seen transmissions for my car going for $40 on Craigslist. But then who knows what shape its in so you could be pulling it in a matter of weeks or never. A rebuild is way more expensive but you know for sure you're transmission is good to go for a very long time.
Your mechanic probably won't do a transmission rebuild. They would generally pull it and send it to a transmission shop to have the work done.
Here's an idea of what's going on: https://honda-tech.com/forums/tech-misc-15/your-transmission-knocking-when-you-idle-loud-i-fixed-mine-pics-parts-1999434/
eH.
I never narc'd on nobody!
Uh...no. The input shaft bearing is inside the transmission, yes. The pilot bearing, however, is not. It's sandwiched in the flywheel. The flywheel should always be resurfaced when replacing the clutch, and the pilot bearing should always be replaced.
But the cause of the OP's problem is the input shaft bearing and that isn't something changed with a clutch.
My mistake on calling the main shaft/input shaft bearing a pilot bearing as well.
eH.
eH.
talks to himself
I'm confused. It's a squeaking noise, right? I literally JUST finished a transmission and clutch job to replace bearings. But, my noise was a grinding noise.
I thought squeaking was a resulting of poorly lubing the shift fork?
Is it a constant squeaking after the clutch has been released or is it only when during the moment when it's being released?
talks to himself
The squeaky sound ONLY comes up when you let off the clutch completely. It's not a grinding sound or a crunch. It's like a low sounding chirp. But constaint when in neutral until I touch the clutch.. And then inside the cabin the clutch makes what sounds like a rusty spring stretching out when I push in on the clutch.
The throw-out bearing make noise when the clutch it depressed. The ISB makes noise when the clutch isn't.
Take it to a transmission shop. They'll diagnose it for free or at the very least they should do an inspection on it for free.
eH.
Here's an idea of what's going on: https://honda-tech.com/forums/showthread.php?t=1999434
Are you hearing the sound with the hood open coming from the transmission?
Are you talking about hearing TWO DIFFERENT SOUNDS? One from the transmission when the car is in neutral and your foot ins't on the clutch, isn't anywhere near the clutch?
And then another sound when the clutch pedal is moved coming from the movement of pedal itself?
eH.
It's your Input Shaft Bearing (ISB). Google it.
eH.
eH.
DelCarajo
11-09-2014 06:58 PM
