SOHC ZEX cam question???
Re: SOHC ZEX cam question??? (japspecjohn)
Yes use the Z6(same head), I heard the JDM D15b is pretty agressive already(don't know specs) so you won't see much gains.
Re: SOHC ZEX cam question??? (biassj)
I heard the same but dont know the specs either but they said it was same as the lower model cam There is two they sell for the z6 ones, suppsoedly 12hp and ones like 14hp doubt that much horse but anything helps.
i've heard the stage 2 is much better than the stage 1. I wouldn't even bother with the stage 1. Get the stage 2 with part number 59300
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn »</TD></TR><TR><TD CLASS="quote">Will the zex sohc cams work on a d15b?
thanks
John</TD></TR></TABLE>
yes it does work. timing will need adjustment by about 5degrees either way (will depend on how you install the timing belt) this will be due block height and cam timing.
when buying go with the 59300 or even crower stage 3 otherwise you will not see any improvements. I used to run the 59300 in my d15b improvements past 5.5k rpm can only be noticed.
improvements with 3-5whp can only be noticed don't think you'll see more then that.
http://www.hadamotorsport.com/...x.htm
thanks
88civichbz6
12-03-2004 03:41 PM
