SOHC ZC injector impedence??
Old 06-06-2006, 10:14 AM
scmil95eg's Avatar
Default SOHC ZC injector impedence??
don't have my voltometer with me. anyone know?
Old 06-06-2006, 11:11 AM
schardbody's Avatar
they are the same as any other civic for that obd
Old 06-06-2006, 11:20 AM
scmil95eg's Avatar
Default Re: (schardbody)
obd0. high or low? btw - i did search.
Old 06-06-2006, 11:23 AM
scmil95eg's Avatar
Default Re: (gdmfsob069)
i googled it. i think they're low. can anyone confirm?
Old 06-06-2006, 11:40 AM
schardbody's Avatar
NOPE, obd0 uses a resistor box, which means what???
Old 06-06-2006, 12:59 PM
scmil95eg's Avatar
it's my understanding that a resistor box is to run low impedence injectors with high impedence drivers. f it. this is retarded. i'm going to flow test the d15 and zc injectors i have tomorrow so i'll know the impedence of both and if the d15 injectors flow close to the same, i'm just going to use those. i just want to drive this f'n car again. i miss autoxing.
Old 06-06-2006, 01:27 PM
schardbody's Avatar
well, you answered your own question. i was saying no i wont confirm it, cuz i knew you could figure it out on your own.
Old 06-08-2006, 09:22 AM
scmil95eg's Avatar
just got done flow testing both sets of injectors and the results really surprised me.
the d15b7 injectors have 168,000+ miles on them and flowed within 1.5% (26.5 lbs/hr to 26.1 lbs/hr)
the zc injectors supposedly have around 40,000 miles on them (but i have no way of knowing for sure) and had a 4% difference
plus, the d15 injectors had a nice, even conical spray pattern where as the zc injectors sprayed like ****. i cleaned and backflushed both sets before testing them so dirt/carbon shouldn't have been a factor.
would have guessed the d15 injectors would have been way more 'off'
anyway, the del slo should be up and running again this weekend after a 4 year rest and hopefully i'll be autoxing sunday morning.
ohgodbadname
05-26-2012 02:38 PM
jining
10-08-2009 01:53 PM
miketurbohonda
11-27-2004 06:12 AM
Morbspeed
01-13-2004 05:51 PM
Quick Reply: SOHC ZC injector impedence??
