SOHC motor delema...
i am in a delema on what sohc motor to buy at the moment. It is between a d15b with hydro tranny and P26 ecu. Or a complete d16z6 swap. Both will eventually boosted ( might even keep it out of the car and build it to make it easier since my motor right now is still running like a champ d15b7 w/ 154k) If anybody has an vital information of opinions they would like to share that would be awesome
Re: SOHC motor delema... (slowdx9585)
i got a jdm d15b vtec, longblock, buy it from me 300 buck plus ship, its as good as a d16z6, but unless its a jdm go with the z6
Risky Business
Re: SOHC motor delema... (boostedcivichatchbacksi)
D15B w/ tranny will be more expensive, but will have less miles and probably run better.
The Z6 will be cheaper to come by (theoretically) but most are old and busted and need a complete teardown to run good again.
Re: SOHC motor delema... (BauleyCivic)
just finished a d15b swap in my 92 dx and it is suprisingly strong well worth the money paid to hmotorsonline.... also used a P08 ecu and the d15b trans(same as ex/si)
Re: SOHC motor delema... (SOHC_MShue)
my friend has d15b with cx tranny and chipped p06 ECU. Runs pretty damn good, I'm going to trow a nice clutch on for him and this thing will be a pretty nice car.
be professional
Doesn't really matter if you ask me; not a huge difference between the two. Just buy whichever one you come across first.
Re: SOHC motor delema... (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">my friend has d15b with cx tranny and chipped p06 ECU. Runs pretty damn good, I'm going to trow a nice clutch on for him and this thing will be a pretty nice car.</TD></TR></TABLE>
ewwwww cx tranny . Tell him to get an ex/si tranny and that thing will rip
Re: SOHC motor delema... (jwn7)
yeah especially .1 displacement, doyeee. thanks for making us all stupider by repeating that idiotic crap that has been proven wrong time and again. i hope that you were kidding.
replacements for displacement:
turbo
compression
technology
efficiency
etc.
the D15 vtec and D16Z6 have similar hp and torque curves if im not mistaken. .1 nothing. The D15 can theoretically handle more power.
turbo
compression
technology
efficiency
etc.
Risky Business
Re: SOHC motor delema... (shaundrake)
Yeah...plus the D15B has a better rod stroke ratio allowing it to rev higher.
There is essentially no difference between the two. But i'd get a D15B because its likely to have less miles.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake »</TD></TR><TR><TD CLASS="quote">yeah especially .1 displacement, doyeee. thanks for making us all stupider by repeating that idiotic crap that has been proven wrong time and again. i hope that you were kidding.
turbo
compression
technology
efficiency
etc.
the D15 vtec and D16Z6 have similar hp and torque curves if im not mistaken. .1 nothing. The D15 can theoretically handle more power.</TD></TR></TABLE>
1. He was obviously joking, since there is only a .1 liter difference between the two. Chill out kiddo.
2. There really is no replacement for displacement.
If you want to talk theory, then a higher displacement engine with any of those items you listed will make more power than a lower displacement engine with the same setup. Period.
turbo
compression
technology
efficiency
etc.
1 Post
z6 - 178,000 original miles - redline and or hit vtec shifts at least 6 times a day! - Regular oil changes and have replaced two timing belts - no issues at all - burns/ uses NO OIL.
my .03
my .03
i would say go with the jdm 1.5 vtec you can get everything for around $500 my friend just got one because they are just as good for boost and the cam is a lillte more radical than the z6 so they put down just as much power as the z6 check round and see what u can get one for. u can probably get one cheaper than buying a z6 and rebuilding it i think ardperformance.com has them with ecu for around eight hundred which is pretty good but u can probably get one off ebay cheaper.
Re: (93gsrciviconnos)
yes true the d15b has a more agressive cam, but just think about it. The z6 makes about the same hp with a less agressive cam. So just think about how much power you will make with a similarly agressive cam as the d15b in the z6 such as the zex stage 2 cam then you will make a lot more power.
Risky Business
Re: SOHC motor delema... (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">z6 - 178,000 original miles - redline and or hit vtec shifts at least 6 times a day! - Regular oil changes and have replaced two timing belts - no issues at all - burns/ uses NO OIL.
my .03</TD></TR></TABLE>
Yeah how many other Z6's you think are taken care of? My B7 head when I removed it was gold...regular oil changes etc. Both my Z6 head and tranny are beat to ****...honestly I wish I had gotten a JDM D15B but I can't go back now.
D15B
D15B
