Sohc Del Sol build
Old 09-28-2011, 07:44 PM
delsol28's Avatar
Default Sohc Del Sol build
Bought the car stock and starting building right away started mostly with body work; skunk2 springs on kyb struts, skunk2 front and rear camber kits, new ti-rods, and new strut mounts. Then i moved to the motor i swapped another d16z6 into the car and had a custom turbo kit made. As it sits its running about 8psi and i estimate like 175hp. This winter im pulling the motor doin a engine bay tuck and shave, and building my first motor. here is what im thinking:
75mm wisco pistons-
Radiator and hoses
Eagles h beam rods-
acl bearings-
comp cam 59300-
supertech valves springs-
supertech valves (STD)-
Blox retainers-
Supertech bronze valve guides-
machined-
skunk2 intake manifold-
68mm throttle body-
AEM fuel rail-
skunk2 cam gear-
Ram style manifold
Darton Wet sleeves-
Supertech block guard-
Timing belt
Turbo
LSD tranny
Stage 2 or 3 Clutch
Lightweight flywheel
water pump
Oil pump
Let me know what you guys think im hoping for about 350hp any ideas like changes or anything to get that kind of power??
delsol28 is offline
Old 09-28-2011, 09:01 PM
slumdog's Avatar
Default Re: Sohc Del Sol build
nice work looks clean, i have a bolt on d16z6 in a 94 eg looking to do similar build. what are you running for ecu management?
slumdog is offline
Old 09-28-2011, 09:15 PM
Two Piece
Go_Race_Your_Self's Avatar
Please take spoiler off... look so much better without.
Kev
Go_Race_Your_Self is offline
Old 09-28-2011, 10:39 PM
virgineg6's Avatar
I agree ^, just a suggestion though.
virgineg6 is offline
Old 09-29-2011, 04:44 AM
delsol28's Avatar
im just got the stock ecu tuned on chrome...once the build is done ill be running a dyno tuned hondata...and for the spoiler i like it cuz its different i never see those spoilers.
delsol28 is offline
Old 09-29-2011, 05:01 AM
barrett_5's Avatar
nice build. in for build of engine over winter
barrett_5 is offline
Old 09-29-2011, 05:44 AM
Two Piece
That spoiler is on every ones delsol. ebay special. Click my profile and you see my delsol. Looks clean without spoiler. Take yours off and I bet you will think the same.
Kev
Old 09-29-2011, 05:49 AM
<MeanDelSol>'s Avatar
Kev
Agreed
But looks good
<MeanDelSol> is offline
Old 09-29-2011, 05:51 AM
xDelSolx93's Avatar
What fogs are those? I want.
xDelSolx93 is offline
Old 09-29-2011, 07:40 PM
delsol28's Avatar
just the stock fogs that come on the car i went to the hobby shop and picked up some clear amber paint and painted them...and i disagree about the spoiler i have never seen that on any other del sol
delsol28 is offline
Old 09-30-2011, 04:03 AM
xDelSolx93's Avatar
I think it would look so much better wingless, but to each their own.
Old 10-02-2011, 03:12 AM
LastKingss's Avatar
spray this sucker white !
LastKingss is offline
Old 10-02-2011, 06:11 PM
delsol28's Avatar
ha no way first thats a brand new paint job and second white is way to common
delsol28 is offline
Old 10-02-2011, 07:11 PM
OmgDelSol's Avatar
Nice build. I actually agree with u. I've never seen that wing and thought it looks pretty good compared to the other wings I've seen.
OmgDelSol is offline
Old 10-02-2011, 08:00 PM
delsol28's Avatar
thanks man
delsol28 is offline
Old 10-06-2011, 04:12 PM
markz95.4dr's Avatar
What's up, I'm doing pretty much the same swap. I have a d16z6 I'm trying to put the aem fuel rail and skunk 2 manifold on but I can't seem to figure it out. U have pics? check out my thread maybe you can help me out?
markz95.4dr is offline
Old 10-06-2011, 09:03 PM
delsol28's Avatar
um post a link to ur post...and what re u having problems wit?
delsol28 is offline
Old 10-07-2011, 06:27 AM
Ekbrent's Avatar
always loved del sols.
Ekbrent is offline
Old 12-25-2011, 01:07 AM
LIL DAn "lsv"'s Avatar
... 350 whp?? What psi are you planning on running? ..
most d-series builds make 220-260 whp @ 15-17 psi sleeved.
if you want 350 whp, I'd suggest a B-SERIES!!!! D= daily lol.. to each their own
How are you going to run a block guard with sleeves?
I always loved del sol's also..color is unique..here in wisconsin you rarely see em this color..
as for 350 whp good luck im interested to see what your D-series does but looks like e-85 and 20+ psi will make 350 just sayin..
what are you going to do for axles? turbo size?
...btw youll hae yourself a race one of these days dj..
LIL DAn "lsv" is offline
Old 12-25-2011, 05:09 AM
The Grumpiest
grumblemarc's Avatar
All this talk about PSI and horsepower and not once was the turbo mentioned past it being a "turbo". Fail. If you have to ask if you can make a certain amount of power out of parts you already bought/plan on buying then you didn't research well. Looks like you copied someone's parts list and started hoping for the best.
If you want to make a certain HP you pick the turbo that will get you there FIRST.
grumblemarc is offline
Old 12-25-2011, 07:25 AM
haha, I agree fully with you sir! Ie heard through other friends that the O.P. STATES, " 15PSI I WILL MAKE ATLEAST...ATLEAST 300WHP...
to the O.P. : GOOD LUCK WITH THT DJ....SEE YA @ great lakes if u want a real race...
Old 12-25-2011, 09:18 PM
good luck for 350 whp. Honestly build it around a precision 62/62
Old 12-26-2011, 10:01 AM
97 DelSol SI's Avatar
Looks good so far, good luck with the hp goal though...although you have the z6 rather that my y8
97 DelSol SI is offline
Old 12-26-2011, 10:16 AM
Wrona's Avatar
im sorry but whats wrong with the y8? its crappier motor than the y8 it like to spins rod bearings
Wrona is offline
Old 12-26-2011, 12:05 PM
blackmugensivic's Avatar
Really only 220-260 @ 15-17psi sleeved? You need to look through the SOHC Turbo thread, my old coupe made 237whp @ 10psi on a bone stock D15B with arp headstuds. The OP's goal of 350 is very achievable.
Looks good OP keep it up
blackmugensivic is offline
Quick Reply: Sohc Del Sol build
