slow windows need some help
what can i do to speed up my passenger side window?? i just installed window modules to my alarm system and it rolls passenger window up slower than the driver, it does this normally w/ out the windows jsut by me rolling the windows up and down.. is it something i can do to the track? new motor? what i would like to fix this.. thanks
Re: slow windows need some help (95CivicEX)
i had the same problem and i sprayed some pyroil silcone lub in the tracks and it started working way faster again try that if that dont work try motors.
DEF
DEF
Re: slow windows need some help (deftones0817)
DEF
DEF
thanks
Re: slow windows need some help (allmtrSI)
i bought my si off the lot and i had the same problem... its been that way for almost three years now but it doesn't bother me.
BTW, I am glad it wasn't just me with this problem. Isn't it funny how something will really bother you, but if you find out that everyone else has the same problem, you don't care has much???
Guest
Posts: n/a
Any recommendations? It's seriously annoying.
where do i put this spray?? on the track or on the window?? and why does it seem to go slower at night or when its colder outside???
thanks
thanks
You can get silicone spray from a auto store.
Re: slow windows need some help (B18C-EJ1)
The Si has power windows? Sorry I'm a super n00b. Getting my del Sol in about 2 weeks here... Going to look at it tomorrow. Just a quick question. I take it only the Si has power windows? What's lower than the Si?
replace the rubber because over time it gets gunked and hard and stuff making it drag on the window so that can help but if its been holding it back for a while the motor under that stress might need replacing
Re: slow windows need some help (ViZ)
I took it to honda dealer they put new tracks on and problem went away for about 5 months then it came back and i just sprayed lub on tracks all the way down i mean like the other guy said supper slippery and they its been good for about 3 months....i figure i can lub it everyone once in a while make sure to clean windows good after you roll them up and down a bit because lub will get a bit on windows. well thats my advice I hope it helps i would try regulator thing too it sounds like my next investment after suspension.
DEF
DEF
My window had the same problem too.After reading this post I went to go buy "pyroil silcone lub" and put it into the track.Now my window works like a charm.Use this stuff for your slow windows, Pyroil Silcone Lub.
Re: slow windows need some help (FifthGearOnline.com)
here is the order of civic coupe trims from lowest to highest
DX
HX
EX
SI
DX
HX
EX
SI
Re: slow windows need some help (bLuEciVicGuY)
where did you buy this pyroil silicone lub from?? do i need to get it from an auto parts store or will a place like home depot or lowes have it?? thanks
Re: slow windows need some help (VTEC)
ok thanks everyone.. im gonna go hunting for this sylicone on tues and hopefully get it fixed asap.. why does it seem like it goes a lot slower at night time?? it it cause its colder?? it doesnt make sensse
My windows do that **** too. Drives me crazy! My passenger one goes so slow I almost don't even think it is going to go up!
TTT
where the hell do i find this pyroil silcone lube at??? what kind of store will carry it, called around and most people tell me to just buy a new motor but i know it can be fixed cause it gets worse at night time for some reason, a dead motor would mean it would do it all the time day or night..
TTT
Try goin to your KRAGEN store.Thats where I got mine.
we dont have kragen stores in my area of virginia.. what kind of store is it? an auto parts store? grocery store? walmart?? thanks
