Skunk2 Manifold on Y8 (vid inside)
Hey guys a need some help with my car!!!
idk wats goin on with it right now so maybe u guys can help
Thanks
http://www.youtube.com/watch?v=BeUCpgHlWJ4
Thanks
Re: Skunk2 Manifold on Y8 (vid inside)
Yeah it has coolant. air in system??
I want it 2 idle normal!!!
why would it be going from 1k to 2k the whole time
Mine does this sometimes. I noticed it does it in the morning or at night when it's cold, but after it warms up its fine. I just assumed that was the reason.
I have no codes
An the IACV was workin befor when i had it on ym stock Y8 manifold. but ill try an change it an see wat happens.
mine does the same thing after i switched to the skunk2 manifold. i gave up a while ago tryin to figure out why since i dont drive it that much. hopefully you figure it out.
ok well i changed the IACV behind the manifold with a different 1 i had an its the same. idk maybe i should buy i new 1 from the dealer?
Wat else could it be?
I heard stuff about 2 and 3 wire IACV i think
its just a big *** vacuum leak thats all.. you probably have it when you installed your intake manifold. Check and make sure all holes from the intake manifold are plugged into a vacuum hose or at least plugged up.
1 Post
Did you use a new im gasket/ tighten all the bolts in sequence to spec?
Sometimes its the small things overlooked.
Which manifold is it? Race version or street
Yes
An its the pro series IM idk if that street or race
Ill do that 2morrow but was the fast idle control valve?? i just have the IACV on the back of the manifold. An i will try bleedin the coolent 2morrow also
He said it had a B16 Throttle body..
It's the FITV. Pull off your intake tube.. and you'll see two holes on the TB on the firewall side.. Plug the bottom one with your thumb, and see what happens.. If it idles down and idles normal.. You know what your problem is.
Pull off the FITV from the bottom of the TB, and Fill it with epoxy. (That's what I did with mine )
Actually..
If you don't have a FITV;
Pull off the intake tube, And plug the holes one by one with your finger, until it calms down. Once you found out what hole is sucking alot of air from we should be able to tell you whats going on. And if you plug all holes and it still idles, Then you have a vacuum leak somewhere else on the intake manifold.
