Skunk2 ECU trouble
Skunk2 ECU trouble
Does anyone have any answers to their p28 skunk2 rich running condion, and fluctuating idle?? On my 99 EX I messed with the Ignition timing and idle screw both havent helped much. I plugged my stock ecu back in to see if there was a possible vac. leak, but with the stock ecu in it runs as smooth as possible. So far there has been no progress. Is the spoon p28 any better, worse, or roughly the same in performance?? Havent looked into that very much. Any help would be great. Thanks
Re: Skunk2 ECU trouble (SOHCex20)
i have a p28 with the skunk2 program as well.
runs stupid rich, reeks inside the cab, the idle is weird. when i first start the car in the morning, if i dont give it gas, the car will die. i have to rev it a bit for it not to die.
my guess for it dying, is the ecu is dumping way to much fuel, and it is... cause my gas mileage is horrible.
ive played with the idle, didnt help much.
Re: (batmang)
I am starting to invest in a vafc as well to help with the a/f mixture. Hopefully that will steady out my idle and stop dumping all the fuel in the car. Yea gas mileage has dropped a rediculous amount as well. Thanks for the info.
Re: (eK9aT10pSi)
do those run cheaper than the vafc?? I'm not really worried about changing my vtec around either so thanks for the info on that.
D-Rob
10-27-2004 09:24 AM
