a single "click" when going from a stop,help?
Swaggylicious
ever since i dumped the ride I've been hearing this click when im accelerating from a complete stop,i.e stop sign,stop lights,it's coming from the engine bay,suspension related but not sure which side or what.i looked at the cv joints and they werent ripped but they're really oily,and its not a clicking noise like if your cv is bad,it's just a single click
can anyone help me out?
EDIT!!
PASSENGER SIDE STRUT TOWER NUTS WERE LOOSE,THANKS PEEPS!!
Modified by sam21 at 10:25 AM 3/20/2006
Modified by sam21 at 5:31 PM 3/20/2006
EDIT!!
Re: a single "click" when going from a stop,help? (sam21)
you know my car did that after i did a swap too..like if you do a U-turn from a complete stop, it'll click..i remember reading on here a while ago, some guys had the same problem..they retightened the bolts oh the axels, suspension, etc., anyways after they did that, it went a way..i have yet to tighten mine..just too lazy, and it don't even bother me anymore ..good luck!
Swaggylicious
Re: a single "click" when going from a stop,help? (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">check axels. or loose bolts if u did a motor swap or suspension change etc. </TD></TR></TABLE>I checked the boot,how do i check the axels themselves?I just recently installed some coilovers,which bolts should i be looking at here?
Swaggylicious
Re: (INCNTRL4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INCNTRL4 »</TD></TR><TR><TD CLASS="quote">check your lower control arm bushings, mine are gone and it kinda clicks....</TD></TR></TABLE>what do they look like when they're gone?and what's a good brand for a replacement?or just oem?
Swaggylicious
Re: (crnimacak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crnimacak »</TD></TR><TR><TD CLASS="quote">check ur springs that use to hapen to my hatch when i drive sometimes it makes some loud *** noise and finaly when i put coilovers it was fine</TD></TR></TABLE>it clicks AFTER i put coilovers on
Swaggylicious
Re: a single "click" when going from a stop,help? (midnitesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">might be the inner joint of the axle. i had the same problem and one day it just snapped.</TD></TR></TABLE>i hope not,i had the passenger cv axle replaced no more than 5000 miles ago
Re: (pythoner)
have the same problem... and it was after doing the full bushing system
I just replaced the axles, tierods, lower and upper ball joints, wheel bearings, lca bushings, uca bushings. and ditched the front sway bar... still have it
check the expletive out of all the bolts and nuts... i missed the uca bolts and after that it cut the noise down but i still have 1 single click from take off
Swaggylicious
Re: (pythoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">riding "dumped" destroys cv joints quickly....but I want to dump the hatch that I am going to buy</TD></TR></TABLE>hopefully this friday i can get these 15" wheels so i can raise the car a bit and it wont look stupid,i hate how the car looks un dumped
Swaggylicious
Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">have the same problem... and it was after doing the full bushing system
check the expletive out of all the bolts and nuts... i missed the uca bolts and after that it cut the noise down but i still have 1 single click from take off</TD></TR></TABLE>when you mean check it,you mean just make sure they're tight right?
Re: (sam21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 »</TD></TR><TR><TD CLASS="quote">when you mean check it,you mean just make sure they're tight right?</TD></TR></TABLE>
yup, make sure every bolt is on really good.... the last problem would be motor mounts cause when u take off, it shifts everything back slightly.
Ill be puttin in motor mount inserts shortly and let u know if it fixed it. Also, did u get a wheel alignment after the coilovers?? im gettin one tomorrow cause i did new tierods. i hope that might fix it cause im also dumped on H&R race springs and my wheels are asking to rub...
Swaggylicious
Re: (dohcdelsol)
Ill be puttin in motor mount inserts shortly and let u know if it fixed it. Also, did u get a wheel alignment after the coilovers?? im gettin one tomorrow cause i did new tierods. i hope that might fix it cause im also dumped on H&R race springs and my wheels are asking to rub...</TD></TR></TABLE>unfortunately no,i still cant afford a front camber kit right now,gonna shim out the rear sometimes this week...only thing i had done was zero out the front toe at school
Swaggylicious
Re: (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote">Must be your axle giong bad dude. Thats what happen to me.</TD></TR></TABLE>Apparently it's not and hopefully it wont(knocks on wood),the passenger side strut tower nuts were loose
Re: (sam21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 »</TD></TR><TR><TD CLASS="quote">Apparently it's not and hopefully it wont(knocks on wood),the passenger side strut tower nuts were loose </TD></TR></TABLE>
no ****, the ******* bolts were causein the click... i have the same ******* thing and have replaced everything. WHeel alignment didnt solve anything (other then the toe/camber problem)
Ima go over all the bolts tomorrow before class and see if i have the same thing but awesome you found out the problem
