Si sway bar on my 96hb
I know someone on this people has done this before. If you can post some pic of it, and feedback on the installation it would be great.
I just order my Si's Swaybar, hopefully it would be in by next week and I can post some pic of it.
Re: Si sway bar on my 96hb (Peagreenhatch)
You need the rear Si endlinks and all the hardware, D-Cups, swaybar, nuts and bolts and it will bolt on w/o modifications.
If you want the fronts, you need the Si front lower control arms and all the front hardware from an Si.
Good luck,
Good luck,
Re: Si sway bar on my 96hb (Trey)
Sound like alot of work to put on the front sway on, then the rear one. And I thought this was a 2 hour job. Looks like I need to get more then just the Bar and Bracker itself to put the bar on my EK.
Thankx for all the help. If you have more pic please post them
Re: Si sway bar on my 96hb (Greasemonkey)
on this same topic would an ex bar help a cx?
i plan on getting the skunk2 rear 21mm with a beaks kit...
I figured i should do it at the same time.
Slow_import
Suspension & Brakes
08-25-2006 09:15 PM
Nsane1
12-27-2005 05:10 PM
