Shift INDICATOR
Shift INDICATOR
Hey I got an automatic tranny, and for some reason all the sudden My Shift INDICATOR The thing under the speedometer,
PRND12 Well Park is Reverse and N is Reverse D is Nutral and 2 Is Drive 1 is Second and than after on the bottom its 1
Understand? Kinda off?
Any ide ahow to fix this
Re: Shift INDICATOR (BlueIntegraBoy)
there is a "slide box" on the right side of the shifter console, is tells the ECU and gauge cluster what position the shifter is in, there are 2 10mm bolts that hold it on and if you loosen them the box can slide left and right, there might be a possibility the calibration is off, that is very weird though
BDogggUT34
38
04-11-2005 02:19 PM
durangedesign.com
02-05-2003 05:08 PM
