set of 4 strut tower bars?
http://www.ebay.com/itm/4P-40MM-FRON...ht_4130wt_1327
they're selling this set, i know where the strut tower bar goes, but i have no idea where you would put the other 3. anyone know of a picture online or have a picture of it?
Re: set of 4 strut tower bars?
Junk, it's not worth it, and it wont do anything.
Middle rear strut bar.
Other 2, tie bars. they go on the subframe(s)
Buying this is a WASTE of money!
Here some pics links from a quick google search
Lower tie bar http://www.google.com/imgres?imgurl=...QEwAQ&dur=8076
http://www.google.com/imgres?imgurl=...QEwAw&dur=8284
Front lower strut bar
http://www.google.com/imgres?imgurl=...QEwAA&dur=1485
And rear strut bar
http://www.google.com/imgres?q=Civic...r:13,s:0,i:116
They are all good to have since they help to stiffen up the chassis and make the handling crisper in turns. I have upper front and rear strut bars and noticed a big difference after installing. That is a decent set for nice price, cant go wrong.
And rear strut bar
From top to bottom
1 Across engine bay
2 Across rear seats(from top of belt to the other side
3 Under the engine
4 From lower control arm to lower control arm in the rear
and thats a bit too expensive for no name ****. u can get different no name stuff for 70$
1 Across engine bay
3 Under the engine
think id be better off with this? http://www.ebay.com/itm/93-97-Delsol...ht_3552wt_1327
Location: Pensacola, FL and every Court House in Louisiana
one thing to note while looking at those listings on eBay. they are listed as "JDM". there is nothing JDM about them. almost anything on ebay listed as that, and isnt actually oem jdm stuff is going to be garbage. take the 130 and put it into a legit jdm itr rear sway bar.
There's a lot more to chassis stiffening than "throw more metal at it." Notice how between the mounting points and the bars in ALL of those strut bars, there's a joint? That joint completely defeats the purpose of the strut bars. Strut bars are supposed to prevent chassis flex. That joint lets the whole assembly flex. Genius.jpg
Op dont listen to all these strut bar bashers. Go with the first set you where looking at, they are made by Megan Racing which is a good company. I have a ebay front sturt bar and a Skunk2 rear strut bar. Just because the front one is a no namer does not mean is does not work as well as my Skunk2 bar or OEM Type R bars, they all work the same.
It cures what ails ya'
Serious, look up what strut tower bars and the sorts do.
Last edited by purgat0ry; 08-08-2012 at 05:46 AM. Reason: ninja edit: spelling hard
been there done that
OP, save your money and buy strut bars that don't have parts that move or are adjustable in them and they should probably be a name brand or else it's more than likely just gonna be made out of cheap metal. The ones you posted I could probably bend them with my hands.
