Searched ... fixed alot of things.. now i need help
I did a swap into a EK coupe put in a ls motor.
The First CEL that came out was
ELD fixed it .. was a blown fuse #15
2nd was Ignition ouput signal.. (replaced the box twice) Fixed
3rd Iac (code 14) I had a couple wire plugs switched... (I believe) now the cel for it was gone....
But now its idling at 1500-1800 rpm up and down.
Right now i have a GSR TB on a LS obd1 Intake Mani bypassing the Fast idle.. etc etc (The sensor under the TB) with a straight hose to the head. Is this the problem should i just get a OBD1 Ls TB?
The car has no CEL. I even clean the system of air bubbles as much as i can. But the idle went down a bit in my eye and it doesn't overheat anymore..... PLEASE H-T NEED HELP
Modified by Nicaraguense13 at 2:24 AM 8/28/2008
Re: Searched ... fixed alot of things.. now i need help (Pothole987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pothole987 »</TD></TR><TR><TD CLASS="quote">i think they mean 1500 to 1800 RPM</TD></TR></TABLE>i know i was just being a smart ***
Re: Searched ... fixed alot of things.. now i need help (messeduprex)
because the gsr tb doesnt align with the LS tb ...... so it will leak all over the Intake manifold...... should i replace the tb with a LS tb thats what im thinking about doing
Re: Searched ... fixed alot of things.. now i need help (Nicaraguense13)
yeah unless you have a chipped ecu to control the idle cold then you need the fitv thats the reason your car is idling that high
ok thanks hopefully this fixes the idle it actually runs fine juss the constant up down idle
