Sea Foam Trans-Clean?! Not SF engine cleaner. Anyone tried it?
While browsing through the new Autozone in my town (YES, AUTOZONE, NOT NAPA. ) I came across Sea-Foam Trans-Clean. Apparently it triples up as a trans/brake system/rack+pinion system flush/cleaner. Directions are simply drop 1/2-1 pint of this into your trans, and drive for 5-10 minutes, making sure to shift into every gear. Then do a fluid change on the trans.
Its supposed to clean gum/tarnish/buildups much like the engine cleaner version. Anyone tried it? Anyone even heard of it? I was just suprised to see the Sea-Foam, because I was under the impression only Napa carried it, no less to see SF Transmission cleaner.
Got some primer/high temp enamel and brake cleaner to clean up my new brake parts for my rear disk swap while I was there.
Unceasing Measure
Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Yeah it only listed directions for autos, but whose to say it cant go both ways? </TD></TR></TABLE>
The machnisms involved with manual and automatic transmissions are completely different. It will probably work - as in not break anything - but I doubt you'll notice nearly as much of a difference in your manual tranny as you would in an auto.
sleepyhamsterlx
03-15-2004 07:15 PM
Powered by Honda
02-20-2002 12:40 PM
