Rywire s2000 clutch master cylinder into ek questions
found my oem clutch master leaking and began looking into converting to the s2000 cmc, my questions are:
1. has anyone done this conversion?
2. is it a pain to install and adjust?
i have searched for a few weeks and never found a solid answer i have a 00 dx with a gsr if that helps
Re: Rywire s2000 clutch master cylinder into ek questions
just did it Friday , very simple just install with spacer and good to go, def need to upgrade to steel breaded line cause the fitting is on the left side instead of the top like stock
awesome i was going to use rywires full kit what set up did you end up going with? and did you have to adjust anything ?
awesome cause i saw that people needed to make adjustments in terms of the pedal and i havent found anyone who used the rywire kit yet but thanks again ill order it soon and install i wasnt expecting performance upgrades from it just figured clean up and install since mines beginning to leak
the whole kit from rywire is 175 which is a dollar less then what id pay with a checkered sports spacer, carbon kevlar line from goodridge and oem s2k cmc from my work (i work at honda) so i figured wtf i will just order everything from him but wanted a legit opinion of the kit would it be nice to do instead of the stock one and would it be anymore of a pain to adjust, considering i have never needed to adjust mine or have adjusted before. I plan on the rywire harness depending on if he can set up one for my swap but thats down the road. if anyone has pics feel free to post i would appreciate seeing the rywire setup installed but thanks for the info guys very appreciated
ordered the kit yesterday, 186 shipped from rywire said i should see it before friday so well see how it is
figured i would give you guys a small update, install was pretty simple,and i like how it looks over all, i needed to adjust my pedal a bit and think there is still room for a bit more adjustments but overall i am happy with the upgrade. if anyone needs tips or opinions feel free to pm me very happy with rywire and will definitely order from them again in the future.
Fish Twig
Having issues. I have the 96-00 civic pedal set, only needed the brake pedal but what the heck. I have the spacer, brand new s2k cmc.
My issue : there isn't enough thread if I use the spacer. How did you overcome this?
Fish Twig
i didnt have any issue with threads i had a buddy hold it tight on my firewall and bolted it right up w.o it pushed i wouldnt have had the threads through so try that
Fish Twig
I'm about to clean up some alarm wiring and get back at it. I left puzzled as hell because I remember for my integra I had to space it properly. I cut away some of the insulation, thinking that could be the issue but I'll try again.
Fish Twig
Nope, ended up user washers to space it again. I have a feeling its probably because they used shorter studs or something
Sergio_TR
31
10-22-2014 01:48 PM
techtalk
Honda S2000
13
03-27-2014 07:29 AM
