RWD EG hatch?
Old 04-21-2003, 01:07 PM
ITRMunky 01-0839's Avatar
Default RWD EG hatch?
Anyone know of a RWD EG? I did a search and did not find anything. It would take hella work to pull it off, but it'd be tighter than the Olsen twins...
Any idea how something like this might perform? Imagine a turbohatch with the engine weight over the rear wheels!!! It'd be sick!
If anything, I would think making another firewall would be one of the hardest things to work out. Any ideas on whether or not fitment would be an issue?
Old 04-21-2003, 01:08 PM
Spade's Avatar
Default Re: RWD EG hatch? (ITRMunky 01-0839)
I'll get it done.....studied how to do it and figured out it will cost $20,000
if you want to fund it.
Old 04-21-2003, 01:15 PM
Finest's Avatar
What's so hard?
Cut up the rear hatch floorpan, custom mount the motor, align the axles, bolt up the suspension/fork assembly to the rear strut towers, run a custom shift linkage, extend the ECU wires, put up a 1/4" thick firewall seperating the front cabin from the rear.
Of course it would help if you knew how to weld and ****.
Old 04-21-2003, 01:19 PM
Kamin's Avatar
Default Re: RWD EG hatch? (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">What's so hard?
oh yea then you have to totally reconfigure the engine bay for a diffrently mounted engine, cut the firewall, reroute the exhaust, move the gas tank because the differental will go there
its a waste of time and money
you want RWD buy a RWD car.
Old 04-21-2003, 01:20 PM
Spade's Avatar
Default Re: RWD EG hatch? (Kamin)
ANd then some.....your armrest becomes the tranny.
Old 04-21-2003, 01:21 PM
poison's Avatar
I couldn't imagine seeing slicks on the back part of a hatch
Old 04-21-2003, 02:03 PM
SikofFalln's Avatar
Default Re: (poison)
Greg Leone s/p is doing this to an EF. It is in last months issue of Honda Tuning. He is turning his into a Midship though, with a new subframe.
Old 04-21-2003, 02:18 PM
IS3Fifty's Avatar
Default Re: (BseriesPWR)
yeah put a civic body on an s2k!
Old 04-21-2003, 02:33 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (purek9hybrid)
Miata engine and tranny with custom driveshafts and differential/rear suspension. It'll cost less and be slow, but you'll have RWD.
OR
You could buy a 1985 Camaro for $1000, drop a $5000 big block in it and run 10's.
Your choice .
Old 04-21-2003, 02:43 PM
ProjectH's Avatar
Modified by ProjectH at 6:54 PM 4/21/2003
Old 04-21-2003, 02:47 PM
KarmaPolice's Avatar
Default Re: RWD EG hatch? (ProjectH)
yea the nsx engine your talking about was in the front, a local shop in GA put an nsx engine in the rear of a crx its not worth the money and you would have to have a lot of resources if you want rwd buy a rwd like some one said
Old 04-21-2003, 02:48 PM
simplegreenmachine's Avatar
if u want RWD just get a 240, save some money and go faster
MilanoRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectH &raquo;</TD></TR><TR><TD CLASS="quote">There was one done in Japan, some guys at Signal swapped in a nsx engine into a civic hb. Super street had a small story on awhile ago. Here is the story read and drool. http://www.superstreetonline.c..._chop/</TD></TR></TABLE>
Thats still FWD... anyone have pics of the Signal CRX(del sol) with a mid engined RWD turbo b18c5 running 10's
Old 04-21-2003, 02:49 PM
Kamin's Avatar
Default Re: RWD EG hatch? (MonKey Magic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonKey Magic &raquo;</TD></TR><TR><TD CLASS="quote">if u want RWD just get a 240, save some money and go faster </TD></TR></TABLE>
no, dont buy a 240. the prices for 240 are 20-30% over blue book because everyone wants one.
Old 04-21-2003, 02:50 PM
Patron's Avatar
That's not rear wheel drive. It's still front wheel.
Old 04-21-2003, 02:56 PM
ProjectH's Avatar
Default Re: RWD EG hatch? (ptran13)
Just re-read the article and saw that it was FWD, the 240 is not a bad idea for the RWD. I am actually thinking about getting a 240, but I definitely want the S15 conversion I cannot stand the way that car looks stock. Then there is the matter of the Sr20DET or getting a nice turbo kit from xs-engineering.
Old 04-21-2003, 06:12 PM
I thought about it, and the civic hb + RWD fab work would not be so bad...locating everything and trying to halfway balance the car out would be the major issue as far as I am concerned.
I am actually thinking about a 240 project...I'd like to tackle a Sil-80 personally. Maybe the hatch RWD is a bad idea, but it sure would be cool. Imagine the press you'd get on something like that, esp. for a startup shop that wants to make a name for itself...
Old 04-21-2003, 06:22 PM
drunknbass's Avatar
theres a rwd crx that has like 900hp and is powered by a s2000 motor.
i wanted to do it to a 88 hatch cause i came across a s2000 swap with like 8k for realllllly cheap
Old 04-21-2003, 06:34 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
no, dont buy a 240. the prices for 240 are 20-30% over blue book because everyone wants one.</TD></TR></TABLE>
and they are slow
Old 04-21-2003, 06:42 PM
Infamous_Imports's Avatar
Default Re: RWD EG hatch? (hondaguy23)
Mahdavi, that's who you're talking about right hondaguy? Anyways isn't tha CRX still pretty slow? And aren't they always having problems with it?
Old 04-21-2003, 06:47 PM
Who Said's Avatar
i could do it if i had the cash
Old 04-21-2003, 07:01 PM
Kamin's Avatar
Default Re: RWD EG hatch? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
and they are slow </TD></TR></TABLE>
so are civics.
Old 04-21-2003, 07:24 PM
93solsigsr's Avatar
what would be tight is to take a 99-00 hatch and put a S2K engine in it and turbo, then custom run a driveshaft and make it RWD, that **** would be fast and no one has ever done it
Old 04-23-2003, 04:30 PM
TypeRaven's Avatar
souds interesting
Old 04-27-2003, 08:11 AM
Default Re: RWD EG hatch? (Infamous_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports &raquo;</TD></TR><TR><TD CLASS="quote">Mahdavi, that's who you're talking about right hondaguy? Anyways isn't tha CRX still pretty slow? And aren't they always having problems with it?</TD></TR></TABLE>
Yea it runs like 11s and it has problems havent heard anything of it in alogn time i am not a big fan of the guys over at mahdavi since they seem to have really high prices and really high install prices for some stuff(even though i do most my self sometimes i am lazy or lack of tools) but thats just imo
Quick Reply: RWD EG hatch?
