Running on 3 Cylinders
Re: Running on 3 Cylinders (00TurboEX)
I talked to a mechanic yesterday and he said when you have this problem it's alot of trial and error. From the looks of it the cap on the distributor is new .
Could it be a bad valve.
Re: Running on 3 Cylinders (hinds90)
i got some injectors i am willing to sell for 30+ shipping if you want to give them a try. there off a jdm b16a. have you done a compression test?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 »</TD></TR><TR><TD CLASS="quote">I talked to a mechanic yesterday and he said when you have this problem it's alot of trial and error.</TD></TR></TABLE>
Sounds like a shitty mechanic who doesn't know how to diagnose a problem and wants you to spend a lot of money.
Are you getting spark in that cylinder? Is the injector for that cylinder working? Have you done a compression test?
Re: Running on 3 Cylinders (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Are you getting spark in that cylinder? Is the injector for that cylinder working? Have you done a compression test?</TD></TR></TABLE>
Exactly.
Should take very little time to diagnose.
Exactly.
Re: Running on 3 Cylinders (Slopoke)
He isnt even trying to fix it himself. Listen an engine needs three basic things to work. Spark,Air,Fuel. Check each one of those very carefully.
Re: Running on 3 Cylinders (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 »</TD></TR><TR><TD CLASS="quote">He isnt even trying to fix it himself. Listen an engine needs three basic things to work. Spark,Air,Fuel. Check each one of those very carefully. </TD></TR></TABLE>Sir I have been attempting to fix it myself (new plugs and wires) but I came on here to make sure I was touching on all the base if you know what I mean.
Just got done checking the injectors I don't think thats the problem the #1 injector works fine on #2.
If a cylinder dosen't have compression it can cause it to run shitty.
Also upon checking #1 spark plug it is all black if that helps anyone and the car also smokes pretty bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 »</TD></TR><TR><TD CLASS="quote">Sir I have been attempting to fix it myself (new plugs and wires) but I came on here to make sure I was touching on all the base if you know what I mean.
You need to actually check for spark on cyl #1. Pull the plug, stick it into the end of the wire, ground it, and have someone crank the motor and see if the plug is firing.
Then do a quick compression check on #1. If its low, you can do a leakdown test to find out where the problem is(whether its the rings or valves).
Ben76251
10-08-2011 08:14 PM
LSVTEC 91 Civic
25
07-12-2004 01:49 AM
Jmonkey327
02-03-2004 05:15 PM
