rough idle
rough idle
hi guys. new user here. tried searching but couldnt find anything. have a problem with my civic. after warmed up and having been driven for a couple miles, whenever i stop at a light the car "studders" feeling as if it will cut off. has cut off about 3 times in the past 6 months but seems to have been "studdering" for that long. studdering is worsened in the summer when i have the a/c on. tried changing spark plugs but didnt help. any suggestions?
also, just put in an aem cai a few days ago and now for some odd reason, sometimes when idle in "P" or "N" revs will shoot up an down from 800 to 2500 back and forth. just curious about this prob also. any replys appreciated, thanx.
is a 94 civic ex (d16z6) coupe w/ auto tranny; all stock except the aem cai and bosch plugs from autozone
Mr. Badwrench
Re: rough idle (ATLianIntruder)
loose the bosch plugs and go with ngk replacements, but thats not the problem. if you know what your i a c valve is unplug it. if it stalls, clean out your fast idle valve. if it doesnt, you need an i a c valve. you may need a helms to help you out. i have also seen on one rare occasion that a wire was bad goin to the i a c vlave. good luck.
Re: rough idle (boostedcivicsir)
ok, a few more questions. what is a fast idle valve and how do i clean it? what does this iac valve look like and where is it. and whats a helms?
Solbros Owns Me
Re: (ATLianIntruder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATLianIntruder »</TD></TR><TR><TD CLASS="quote">is this my iac valve? </TD></TR></TABLE>
no.....it's righr behind the throttle body and intake manifold mating area....has a black cylinder on one end, 2 hoses into it, and one sensor connection, held on by 2 12mm bolts
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATLianIntruder »</TD></TR><TR><TD CLASS="quote">wow, that was kinda funny. anyway, thanx man.</TD></TR></TABLE>
you making fun of my airbrushing....lol
pull it off WHEN the engine is cool- don't want to be burned with hot water from the hoses.
When you pull it off, you will see a little metal screen...clean it out wit carb cleaner, reset the ecu, plug it up, and see if that helps.
Try adjusting the idle screw also and get your idle at the correct rpm.
Re-gap your plugs to spec, etc, run fuel injection clean, blah blah
Re: (Emerika)
one last thing. how do i get it off. i tried pulling it and it seems to be stuck on there. or am i jus a moron an have to unscrew the bolts off first...
Former Moderator
I would almost guarentee that your problem is NOT the electronic idel air valve that is on the back of the intake manhifold.
I'll bet it's your fast idle valve under the throttle plate on the bottom of your throttle body.
I've sen dozens of those go bad in my 7+ years of working in and around Honda/Acura dealers, and I've never seen one electronic idela air control valve (on the back of the intake manifold) go bad on a 1992-1995 Civic.
Here's what you do:
Pull off the the fast idle valve from the bottom of your TB. It'll be held in by maybe 4 10mm nuts. It'll also have a coolant line on it or two, so disconnect those too.
Then take a phillips head screwdriver and take off the two screws on the end cap and look inside.
Inside there will be a big plastic plate that should be screwed into the FIV itself. Usually this spring-loaded plate comes unscrewed and messes up your idle. Take some RVT sealant (preferably Hondabond) and put it on the edge of the plastic disc. Screw it back in about halfway and reinstall the FIV.
Adjust the idle via the throttle mixture screw and that should pix the problem.
If the spring inside of the FIV is broken then buy a new FIV for like $40.00 or something like that from Honda.
Here's what you do:
Re: rough idle (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">I would almost guarentee that your problem is NOT the electronic idel air valve that is on the back of the intake manhifold.
Here's what you do:
same situation happen to me this is what i did
Here's what you do:
Former Moderator
Look here:
http://www.hondaautomotivepart...+BODY
The part you're looking at is #10
See the plate, I think it's number 2 in that pic. That's what needs to be screwed back in.
Hey, Tom should that work on my ZC too?? Its and OBD version of the motor, I cleaned my idle control valve and it worked a bit...but my idle still sits funny once in awhile...??
Could it be my dizzy??
Former Moderator
Re: rough idle (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm »</TD></TR><TR><TD CLASS="quote">Hey, Tom should that work on my ZC too?? Its and OBD version of the motor, I cleaned my idle control valve and it worked a bit...but my idle still sits funny once in awhile...??
Could it be my dizzy??</TD></TR></TABLE>
You have any check engine lights or codes stored?
my check engine light has not turned on......it did once a while ago (like 2 months ago) car pulls the same just idles high during arm up and then after driving it it idles low....I have adjusted idle with the screw and nothing....
Just trying to figure it out......
California_Gurl
03-10-2012 09:35 AM
SuM Honda
01-01-2010 07:29 PM
