Rota MSR's vs Rota Sub-Zeros Questions
New User
I know the Sub zeros are light weight
but how about the MSR's from Rota they are identiacl except the MSR has is 6 instead of five
anybody know the specs on the MSR's?
Re: Rota MSR's vs Rota Sub-Zeros Questions (azn_outlaw)
Weights for Rota MSR:
15x6.5 - 16.9 lbs
16x7 - 17.2 lbs
They are heavier than the Sub-Zeros or Circuit 8's, but not by a whole lot.
[Modified by spyder, 9:36 PM 10/15/2001]
15x6.5 - 16.9 lbs
16x7 - 17.2 lbs
Re: Rota MSR's vs Rota Sub-Zeros Questions (spyder)
actually
17lbs vs 12lbs (Rota SlipStream or C9 or Sub-Zero) is huge difference on a rim since the weight is a unsprung weight, which is 4x greater in effect then regular weight.....the difference is as much as adding 80lbs to the car vs the lightweight setup
means suspension, motor will have to work much harder....lightweight rims are like lightened flywheel...
trust me go with lightweight, otherwise you'll regret it...
Re: Rota MSR's vs Rota Sub-Zeros Questions (eg6ajk)
First of all, let me correct my original post. I had originally posted the 16x7 MSR's as being 17.7 lbs, they are actually 17.2 lbs. I have updated my original post to reflect this.
yes, I know all about unsprung and rotational weight.
You are comparing different sizes of wheels. You were comparing the 16" MSR's against the 15" Slipstreams, C8's and Sub-Zeros.
16" MSR's weigh 17.2 lbs. 16" Sub-Zeros weigh 14.5 lbs. Yes this is still a significant difference, but not as much as the 17lbs vs 12lbs you were saying it was. But I agree, you will probably notice the difference.
[Modified by spyder, 9:37 PM 10/15/2001]
Wow, I traveled back from 2001 i feel cool!
I wanna know where i can pick up the ROTA MSR at? i have 3 of them but missing the 4th one.
