Is this the right rear swaybar for a EG Civic? Please look!
Before I buy this used online, just want you guys' expert opinions -
http://www.imagestation.com/my...bum=1
- does this look like Suspension Techniques part # 51145, which is a 3/4" (19 mm) diameter rear sway bar that fits a '94-01 Integra or '92-95 Civic Si?
Thanks in advance.
Thanks in advance.
Re: Is this the right rear swaybar for a EG Civic? Please look! (CRXMR2SM2)
ST swaybars are good. i'm not sure if thats for a 92-95civic/94-00integra
Re: Is this the right rear swaybar for a EG Civic? Please look! (jL iLLuZiOnz 9)
Thanks dude, I like ST bars b/c I have them on my CRX, and I'm pretty sure it's a real ST part b/c it's the right color grey, but I'm not sure the bends look right compared to my stock piece . . .
- anyone else got an opinion?
errr. i'll give u an answer later... i have an ST rear sway bar on my EG. i honestly dont recall it looking like that, but i will certainly check for ya as soon as i get off work and get home...
heres a pic of mine installed, try to compare... might be............ i have more pics of it uninstalled at home too. i'll let ya kno.
Re: Is this the right rear swaybar for a EG Civic? Please look! (n3rdsp0rts)
Thx n3rdsp0rts, that looks like it to me. I'm buying it used off somebody on thepartstrader.com and I wanted to reassure myself I wasn't buying the wrong part.
BTW, did you just drill a hole and mount your sway bar endlink to the stock Civic LCA??? Is that safe/kosher? It looks like you tapped it for the threads instead of putting it though the lower control arm with a bolt and nut . . .
thanks,
Hsun
thanks,
Hsun
the ST bars usually mount to L brackets that use the shock bolts.
not the OEM location further inboard.
Re: Is this the right rear swaybar for a EG Civic? Please look! (Doctor CorteZ)
sorry that it isn't so clear, but it looks to be the same.
this is the L bracket (paintbrush drawing )
i'll take a pic of the L Bracket on my car in a sec and upload it.....
Here are the L bracket pics I told you about.... i bought a piece of angle steel from Home Depot, cut a 1.5" more or less. Then, drilled a hole on both sides (forget drill bit size). i thought it wouldn't be strong enough, but its been holding up more than fine for over a year now!!!
GOOD LUCK on yours
GOOD LUCK on yours
Cool, awesome info - thx very much! Now I don't have to bother to get Integra LCA's! Now I understand why the bend looks different than a stock GSR rear bar - it's designed to attach at a different point.
How thick is that angle iron? 1/4"? Or is it thinner than that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXMR2SM2 »</TD></TR><TR><TD CLASS="quote">Cool, awesome info - thx very much! Now I don't have to bother to get Integra LCA's! Now I understand why the bend looks different than a stock GSR rear bar - it's designed to attach at a different point.
How thick is that angle iron? 1/4"? Or is it thinner than that?</TD></TR></TABLE>
it's at least 1/4" for sure. I've been using the ST sway bars for almost 3 years now and no problems with cracking on the subframe.
cranberry
Suspension & Brakes
07-14-2010 10:10 PM
