results of valve adjusting
well i finally broke down and did it wow. I knew the vavles were off but i had no clue how much. they were like .06+, i adjusted them to factory spec and wow it is quite and there is tons more power and all in all it is just smoother.
look dude this **** is easy i guess that is why honda only charges 108.99 to do it. it is really easy. I searched on here and i found some directions on how to do it. took less than an hour but then i painted my valve cover (yea it is ballin textured black) that took alittle longer.
One of the snap on valve tools makes it a million times easier and faster. I also got a really long ratchet extension (24") so that I could do it without taking the tire off. You will also need honda bond and a new valve cover gasket, and plug well gaskets to do it correctly.
Re: (-TRINiTRON-)
i just use a 10mm wrench and a screwdriver to adjust them. it's easy as ****. just make sure to tighten the locking nuts down TIGHT or they'll come lose with a quickness. also, make sure the motor is below 100 degrees before you do the valve adjustment.
