Results of a bad TPS
I'm still having an idel problem. Car idels high then low, high then low...etc. Think it could be my TPS? Please help me out, this is really annoying. Didnt do this until I put the new TB on.
just put a cover sheet on it
Anyway, I had the same problem and it turned out to be a dirty filter on my IACV. Clean that filter with some brake cleaner and you should be golden. If that doesn't work let me know, I saved the other stuff people told me to check if it didn't work.
Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">just put a cover sheet on it
Anyway, I had the same problem and it turned out to be a dirty filter on my IACV. Clean that filter with some brake cleaner and you should be golden. If that doesn't work let me know, I saved the other stuff people told me to check if it didn't work.</TD></TR></TABLE>
It didnt do it before I put the TB on though. Thats why I think its the TPS.
The IACV is a little contraption on the back of the intake manifold... it has 2 bolts. Pull it off, remove the gasket, put some brake cleaner on a rag, rub the filter. It should look much cleaner. Re-attach IACV and go.
Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">CEL = Check Engine Light</TD></TR></TABLE>
Thats off...
Thats off...
Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 »</TD></TR><TR><TD CLASS="quote">Even if you don't think it's the IACV it's worth the 5 minute it takes to clean it, ya never know, it could be the issue.</TD></TR></TABLE>
Whats the IACV look like?
ya it's pretty much the only thing back there... mine is a metal piece with some black plastic thing on the end of it. it has two lines attached, I think they both held coolant.
UNDER PRESSURE
10
06-15-2004 04:09 PM
