Resetting civic 5g codes
I need help clearing the check engine lite...the code i got was a "41" O2 sensor...I changed the sensor already, just need some help resetting it...Any info would be helpful..thanks to who read this...
Re: Resetting civic 5g codes (PsYcHoCiViC)
Either pull the backup fuse for 30 full seconds from the engine bay fuse box (7.5 amp)
Or pull your battery for 30 full seconds.
Once you replace, start the car and leave it alone until the fan cycles twice.
NO TOUCHING THE GAS. The ECU needs to "learn" all the sensors again.
Re: Resetting civic 5g codes (SlowCivicHmm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm »</TD></TR><TR><TD CLASS="quote">back up fuse?? what about the blue fuse label'd ecu??</TD></TR></TABLE>
spade means the ecu backup fuse.
