Replaced Dizzy... Not starting Wrong Wiring?
my dizzy in my b16a2 with another b series dizzy/ Would it not work if it was from another engine?
it turning over but not on.. my old bad dizzy went bad but would till turn on
ICM was bad
can i switch in the ICM from the new dizzy and pit it in my old one
ICM was bad
Re: Replaced Dizzy... Not starting Wrong Wiring?
what's the code on your dizzy? I'm sure I can help you get it runnin. Text the number in my forsale thread and ill see if I can get you hooked up
i just got a new one actually and popped it in.. still didnt start
turns over though... have to get it running by monday though...
That's what I used to think too. Some aftermarket dizzy's apparently can be installed 180-degrees out of phase. Some people also claim to have been able to force on an OEM dizzy out of phase.
OP: Any CEL codes? Have you checked whether there's no spark at the plugs?
Chances are with aftermarket dizzys the dizzy gear gets installed backwards. When its supposed to fire cylider #1. It fires number 4. Therefore the gear needs to be swapped around. Common mistake on aftermarket dizzys.
no its defienently in correctly.... it threw a ignition output signal code before i took the dizzy out thinking that it had gone bad.... i popped a used one in and it wouldnt turn on just turned over... then i bought a brand new one and it did the same thing
havent checked for spark because it fired right up even with the old busted dizzy before and cant understand what it possibly be
firing order rite? have u had someone crank it to see if ur getting spark at all? u sure the fuel pump is priming i know i had an issue like this and i blew a fuse maybe check those too while ur at it....
Get back to basics. Making any assumptions will just slow down finding the fix. Check for spark and priming of the fuel pump. Click the Check Spark link in my signature. Any CEL codes?
yes it is getting spark
it started up then died again after about 10 mins ... back to where we started
no CEL at the moment but beforehand it threw a ignition output signal code.. thats why i changed the dizzy
not sure about fuel pump priming... i heard something click when i turned it to the on position figured it was the main relay
When the engine won't start:
Is there bright white spark at the plugs?
When you turn the key to ON(II), you do you hear the low humming/buzzing noise of the fuel pump priming for 2 seconds in the gas tank.
spark was kinda orangy and white... tried 3 different dizzy all the same result
cant be sure about the hum though... i didnt hear anything other than the click of the relay and then the power locks click over...
Remove the gas cap, press your ear against the fuel fill hole, and then have a buddy turn the key to ON(II). Do you hear the humming/buzzing of the fuel pump for 2 seconds.
well the fuel pump is good... i have a FP guage and its reading it like it would normally do.... im going to check my grounds and and voltage to the injectors next...
Like spark plug wires? i havent seen many plug wires go bad unless there frayed which mine arent
its hard to look at a spark plug wire and tell if they r good or not.. check the amount of resistance in the wire.. or take a wire off one at a time while the engine is running
