Removing SRS steering wheel, and installing intermitent wipers
#27
Re: Removing SRS steering wheel, and installing intermitent wipers (Arkiteckt)
ok stupid question, WTF is "intermitent wipers".
And whats the difference or benefit of having these over your stock ones?
#28
Re: Removing SRS steering wheel, and installing intermitent wipers (137)
Many civics came with only low and high speed wiper controls. The low is insanely slow, and the high is pretty damn fast. The intermitant is the much needed middle speed.
#29
Re: Removing SRS steering wheel, and installing intermitent wipers (prestoizm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prestoizm »</TD></TR><TR><TD CLASS="quote">
Hey what kind of cluster is this? I have an EG6 cluster but it only goes to 140km/hr. Yours is at 220km/hr. That looks sick! </TD></TR></TABLE>
It's an EG6 cluster with an aftermarket speedo, usually used by race teams where the 180 is just useless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 »</TD></TR><TR><TD CLASS="quote">ok stupid question, WTF is "intermitent wipers".
And whats the difference or benefit of having these over your stock ones? </TD></TR></TABLE>
The intermitent is the one that only wipes around every three seconds, good for when it is not raining, just drizzling.
#35
Re: Removing SRS steering wheel, and installing intermitent wipers (vtec69)
do i have to do the wiper switch part along with the srs removal? because all i want is my 95 integra to have my momo wheel put on.
#37
Re: Removing SRS steering wheel, and installing intermitent wipers (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">
don't euro clusters have higher marked speedos also? i remember seeing a UKDM ef with a 150mph speedo... a 180kph speedo would suck on the autobahn.
#38
Re: Removing SRS steering wheel, and installing intermitent wipers (eymnewdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eymnewdc2 »</TD></TR><TR><TD CLASS="quote">do i have to do the wiper switch part along with the srs removal? because all i want is my 95 integra to have my momo wheel put on.</TD></TR></TABLE>
If you are just adding an aftermarket steering wheel, than the only thing you're going to have to do is a the horn shoe, and run one wire from the SRS harness to the plug on the back of the right hand turn signal. There's a link in the first post on this.
#39
Re: Removing SRS steering wheel, and installing intermitent wipers (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
don't euro clusters have higher marked speedos also? i remember seeing a UKDM ef with a 150mph speedo... a 180kph speedo would suck on the autobahn.</TD></TR></TABLE>
Yes the European ones go higher generally 220-300 depending on the car, the Japanese ones go to 180.
#40
@ 92b16vx .... thanks for answering my question. i know its a long *** post. ill get to it soon.
#41
okay im doing the intermittent install onto my 94 CX but i am having a problem.
i managed to grab a wiper stalk from a 4dr sedan with the INT and i grabbed a ICU relay from a 2dr with INT
i just installed these onto my car without disonnecting the battery and even with the wipers in the off position the wipers were on. they were on the INT setting.
thats when i connected the wires onto the back of the ICU. i then tried my luck again this time disconnecting the battery and also disconnecting the wires but the wipers wouldnt work at all. only if i did the mist thing.
do you guys know what the problem may be?
#45
yes, it is simple but the link at the end of the post is better, thats what i used. its a piece of pie. u can pm me if u need help or if u want to know how to hook up a horn
#46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">don't euro clusters have higher marked speedos also? i remember seeing a UKDM ef with a 150mph speedo... a 180kph speedo would suck on the autobahn.</TD></TR></TABLE>
the one i got for my civic goes up to 220km/h
#48
Re: Removing SRS steering wheel, and installing intermitent wipers (13BT)
i have another question on the INT option...
once the relay is in...what wires are needed to be run from the switch to....relay, wiper motor etc..??? I havent started the install b/c i wanted all the necessary info before i start the process...
I only have the arm switch and im about to get teh relay...anything else?
#49
how do I unplug the yellow to yellow in the second pic? That bitch is stuck.
