Rebuilding head...ok to reuse valves??
hey, i overreved my motor and now im gettin it redone... i bent some valves, not sure how many yet... but i wana know is it ok to reuse the ones i didnt bent?? i dont have the pockets to just do them "just cuz the heads already off and im in there already so i might as well"... so could i reuse em without any problems??
you can reuse the ones in good shape with no problems, but I would recommend replacing the valve guides as long as you have it all apart. the stock ones arent the strongest in the world, and if they are bad you will have blow-by and leakdown.
Re: (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon »</TD></TR><TR><TD CLASS="quote"> but I would recommend replacing the valve guides as long as you have it all apart. the stock ones arent the strongest in the world, and if they are bad you will have blow-by and leakdown.</TD></TR></TABLE>
where and how much do they cost??
Re: (1hotintegra)
you can reuse the valves, but if your going to be building this car to go fast, replacing now would be your best bet while you go the head off. Make sure whoever is doing it reseats all the valves properly.
Re: (godnf8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godnf8 »</TD></TR><TR><TD CLASS="quote">Make sure whoever is doing it reseats all the valves properly. </TD></TR></TABLE>
How would you go about doing that?
cxSHOE
03-29-2004 05:20 PM
andrewasf77
02-23-2004 10:15 AM
