Rebuild - seals, bearings, etc..
1 Post
Hey guys I basically want to piece together my re-build parts before summer or sometime soon. I was wondering if anyone has done this knows how I should go about doing this..
basically I want to replace..
bearings
seals
gaskets
oil pump
waterpump
timing belt (PE enterprise)
Basically I want a fresh block, I was thinking about doing a portflow head or finding an ITR one.
slugs will be oversized JDM ITR pistons, maybe some skunk2 stage1 cams, etc, etc, blah blah.
I just want to piece together the small items right now, so if anyone knows how to go about this I'd appreciate it.
BTW - I went to Acura today and he said ballpark...$2000 for just seals, bearings, etc. Doesnt sound right to me...
thanks guys
bearings
seals
gaskets
oil pump
waterpump
thanks guys
Re: Rebuild - seals, bearings, etc.. (navin)
bearings
seals
gaskets
oil pump
waterpump
bearings
seals
gaskets
oil pump
waterpump
2/3 - 150 tops
4 - 100
5 - 60
6 - why?
your dude was blowing you off so he didnt have to look all that **** up.
BTW - with those little cams you dont really need that belt
[Modified by Doctor CorteZ, 9:00 PM 2/7/2003]
Re: Rebuild - seals, bearings, etc.. (Doctor CorteZ)
Engine running+ close valve to piston clearance+ broken timing belt= smashed valves. Thats why you should change the timing belt.
[Modified by b16matt, 5:10 AM 2/8/2003]
1 Post
Re: Rebuild - seals, bearings, etc.. (b16matt)
I think Doc C is trying to say that I dont need the PE belt because its a "super strong" belt for the stage 1 cams. He's just looking out
yeah stick with an oem belt, save your loot for tuning costs.
Those parts listed wont run you more than $500 total, I am doing a similar buildup right now. There is a thread in best buys for bearing sets for like $100 or $130 , then hit up a cheap acura online dealer for oem water pump, timing belt and seals / grommets.
1 Post
Re: Rebuild - seals, bearings, etc.. (owen_the_soyboy)
Owen,
thanks for the info, mos likely I'll be staying with milder cams now. BTW - are the ACL bearings just as good as a bet as the OEM ones..
boostedeghatch
02-28-2005 09:54 PM
