Rear Main
Old 05-01-2011, 04:09 PM
BlackDB8's Avatar
Default Rear Main
Uploaded with ImageShack.us
This looks like to me a rear main seal coming from where the block meets the transmission between the black plate but not entirely sure this picture was after about 10 mins after i wiped it down you can see the drip my question is should i be overall really concerned or just keep an eye on my oil levels daily as i need this car but don't have the money to get this fixed at the moment second question is would changing to a 10-40 with maybe some additive slow it down
Old 05-01-2011, 04:11 PM
Linked's Avatar
Default Re: Rear Main
what car and what engine is this?
Old 05-01-2011, 04:14 PM
BlackDB8's Avatar
98 civic 1.6L sohc mostly stock other than a few mods
Old 05-01-2011, 04:16 PM
Resident Gearhead
BryanM.'s Avatar
Forget the additives or thicker oil.
Rear main doesn't control any pressurized oil, so no concern there.
If the leak gets bad enough, everything in the bell housing including
the clutch assembly can get saturated with oil.
Keep an eye on the oil level until you get the $$$ to fix it.
Good time to consider doing the clutch too.
Old 05-01-2011, 04:26 PM
Master Detailer
98civdx's Avatar
^ I agree with him.
I'd throw some cardboard or something under it to catch the oil leaking.
It is something to think about, but I wouldn't be freaking out about it.
Old 05-01-2011, 04:55 PM
Former User's Avatar
Rule out a leak from the oil pan gasket, distributor O-ring, VTEC solenoid, and valve cover gasket before you drop the transmission.
Old 05-01-2011, 05:52 PM
-__-'s Avatar
lol good idea.
Old 05-01-2011, 06:10 PM
BlackDB8's Avatar
OK but it most cases isn't it the rear main though if its leaking from that spot?
Just from what i know if it was a solenoid leak i would have oil on the side of the block or the pan gasket oil would be on the opposite side of where its at and if it was the valve cover gasket leak i would have oil on my hood. correct my understanding
Old 05-01-2011, 06:18 PM
O.G. triple O.G.
NVturbo's Avatar
Save the headache and replace the seal. It's much cheaper to do that than buying quarts of oil. What happens if you forget to add oil....engine failure. That will cost way more than that $10 seal.
Old 05-01-2011, 06:21 PM
Not necessarily. Leaks from the other sites I mentioned are much more common.
Have you checked for oil below the distributor, VTEC solenoid, and valve cover? A leak from the transmission side of the oil pan gasket will also appear in the same location.
Have you removed the flywheel cover to see whether oil is dripping from the engine side behind the flywheel?
Old 05-01-2011, 06:32 PM
BlackDB8's Avatar
Ive checked all other places and that's the only place that has signs of oil otherwise my engine bay is clean as far as my oil pan gasket can leak at the same spot i didn't know thats good to know. No i havent taken off the flywheel cover but looks easy enough to do (haven't done it b4) so i don't know if its leaking on engine side or transmission
Old 05-02-2011, 03:36 AM
O.G. triple O.G.
NVturbo's Avatar
BlackDB8, from previous experience, it is actually easier to just pull and remove the motor/tranny out of the car to get to that rear main seal. Removing and prying out the transmission is not easy, especially by yourself. If you haven't already, replace the timing belt, water pump, front main seal, etc. when the motor is out.
Old 05-03-2011, 02:50 PM
BlackDB8's Avatar
So i was looking around again and smelling the oil and swore it smells like transmission oil checked my regular oil levels again nothing has changed been busy but i'm starting to think its a transmission seal of some sort.. maybe a main shaft seal?
ToTriggerHappy
01-08-2011 12:16 AM
dth0ng69
08-29-2009 10:08 AM
mntdewred
15
03-01-2006 06:46 PM
92hondalude
01-12-2005 01:59 PM
Quick Reply: Rear Main
