Rear Glass Handle
Rear Glass Handle **did search**
I had a post awhile ago but I didnt get an answer. I did a search and still no answer. Right now I have two holes in my rear hatch glass where 1) a wiper is supposed to go, 2) a little handle is supposed to go. Im having trouble reading the diagram off of Majestic Hondas diagram. Im wondering what parts Ill need to fill the holes. It looks like parts 14, 12, 15 for the handle but I cant figure out what numbers to use to cover the wiper hole. Is it just a grommet?
A picture of the diagram is in my original post here:
https://honda-tech.com/zerothread?id=657487
That way you can see what numbers Im talking about. Hopefully someone can figure it out or knows which ones Ill need. If you have the part numbers it would be awesome if you could post them.
tried to im you but you didnt answer back even though you were online but anyways, the first hole is just a grommet i think and the second one is like a mini hook as you were saying, i have a body who works in hondas parts dept, ill get back to you if this didnt help, let me know
Re: (superchin)
Sorry I left honda-tech up but was away from the computer. Thanks for the reply.
If you could figure out part numbers for me it would be greatly appreciated. From the picture it looks like instead of a grommet it almost looks like a cover for the screw. I just want to order the right parts so that I have the handle without the rear wiper.
Doe anyone have a picture of the rear glass with the handle and no wiper? Mabe you could post a pic of it and also check and see if it has a bolt in place of the wiper or if its just a grommet.
Re: (Motts)
Man, I tried twice to get the right parts. The first time I went to the dealership, they ordered the wrong stuff. The second time I tried Majestic Honda. Right now I took two of the little grommets I ended up with, put some washers in them and got it to work. No little handle though, and I have a nasty exposed striker on the inside. So hopefully someone can help you/me out cuz I've asked on this and other forums and got nothing.
Josh, I made a handle. Youll see it this weekend. Its no OE peice, but it works.
Here is everything youll need:
95 Civic CX HB
Handle (on left)
90108-SR3-901 BOLT, RR. WIPER MOTOR BASE PLATE $11.79
90105-SR3-000 SEAL, TAILGATE OPENER STAY & WIPER MOTOR $1.35
90109-SR3-000 SEAL, RR. WIPER MOTOR BASE PLATE $3.09
Wiper Delete (on right)
90301-SR3-000 NUT, RR. WIPER MOTOR PIVOT (6MM) $15.03
93402-06012-00 BOLT-WASHER (6X12) $0.43
90507-SR3-000 WASHER, RR. WIPER MOTOR PIVOT (6MM) $1.67
95 Civic CX HB
Handle (on left)
Re: (moto27cm)
Hmm interesting. I actually went to honda and ordered my parts today. Pretty much matches up to your list. I wasnt going to post the p/n until I made sure they were the right ones. Figure Id be the guinea pig. I should have it in before the meet, hopefully.
rsx03
11-30-2001 12:22 PM
