Rear EK Disk Swap w/ LCAs
Guest
Posts: n/a
I was working on my car today, putting in new rear lower control arms (SRR) and some other stuff. I broke the bolt connecting the trailing arm to the LCA. We were thinking about ways to get around it, and someone brought the idea of a rear disk swap up. So on to my questions. If I go ahead and get the GSR brakes for the rear, will I be able to keep my LCAs, or will they not fit? Also, will my rear camber kit work with the new brakes.
Thank!!
Thank!!
As long as I dont have to take out any more Metal Gears
Re: Rear EK Disk Swap w/ LCAs (diearzte2)
the answer is yes u can use ur stock LCAs and ur camber kit will work, however u will still need to get that bolt u broke. That bolt is a major component tying together ur suspension, it supposed to be strong, how the heck did u break it?
PS: u can use integra e brake cables, but its a really tight fit. Try to find some from a 99-00 civic SI, it should fit better
Guest
Posts: n/a
Re: Rear EK Disk Swap w/ LCAs (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">the answer is yes to all ur questions, however u will still need to get that bolt u broke. That bolt is a major component tying together ur suspension, it supposed to be strong, how the heck did u break it? </TD></TR></TABLE>
I really dont know. We had air tools, but they were being innefective, so we tried to strong arm it, and it turned a little then snapped off. I already had replacements because MN winters take a toll on anything underneath the car.
ncVTEC1313
06-03-2004 05:14 PM
