REAR DISK CONVERSION QUESTION ON 96 EK
Besides "99" And "00" Civic Si Proportioning Valve... Can I Use "94" Thru "01" Integra Proportioning Valve... If So... What Years And/Or Base Models. THANKS
Seagull Management
Re: REAR DISK CONVERSION QUESTION ON 96 EK
'99 - '00 Si coupes use the same prop valve as all '96 - '00 Hatchbacks and DX and HX coupes. Sedans are different. If you're using Integra front calipers use a '98 - '01 Integra non ABS prop valve (Integra front calipers have a larger piston the Si calipers and use a different prop valve).
trick of the trade use a 91 civic master cyl forget the part number but go to autozone and get one
you wanna use that so that you dont have to change the lines or booster
Seagull Management
Doesn't work on '96 - '00 Civics, the ears are both horizontal, not angled like most the older stuff. '98 - '01 Integra will fit though.
BRRRRMAN
Suspension & Brakes
05-01-2014 12:39 PM
phatalex1048
12-29-2008 07:43 PM
Jonathan_ED3
03-24-2004 02:50 PM
