High rev on start up
Old 06-21-2010, 07:00 AM
illios's Avatar
Default High rev on start up *pic*
I jus did a swap into my 00 civic ex with a 95 gsr head n b16a2 block.
I hve stock ex harness. Stock ex p2p ecu(for now), stock gsr Mani with b16 throttle body
anyways... When I start my car. It starts up perfectly but instantly revs really high on it's own without me pushing on the gas. So I turn off the car to avoid blowing the motor by high rev. I checked my throttle cable and that is not causing the problem.
So it seems like it is automatically pushing down the gas petal itself. And I have no idea why. Has anyone had this problem before?
Thanks!
illios is offline
Old 06-21-2010, 07:32 AM
delsolo95's Avatar
Default Re: High rev on start up
you sure you got the vaccum lines in the right spot?
delsolo95 is offline
Old 06-21-2010, 07:49 AM
illios's Avatar
not 100% positive.. cuz theirs like so many fukin vaccum lines in the gay gsr manifold :/ would it matter if i just blocked them?
illios is offline
Old 06-21-2010, 07:57 AM
delsolo95's Avatar
its probably why!! lemme link you to a diagram. this is off a 95 obd-1
Old 06-21-2010, 08:00 AM
delsolo95's Avatar
heres obd-2
Old 06-21-2010, 08:14 AM
kaiba's Avatar
How do you the manifold is gay. Did it touch you?
kaiba is offline
Old 06-21-2010, 08:34 AM
illios's Avatar
i noticed i dont have a intake air bypass vaccum tank.. would that cause it at all?
illios is offline
Old 06-21-2010, 08:56 AM
illios's Avatar
i made a quick pic.. not my manifold... but looks exactly the same
a) its not in the pic but on top of that there looks to be a small vacuum hose that i have no idea where it connected.. before i just connected it to "B"
b) no idea where it goes...
c) no idea where it goes... before i had it connected to a small vacuum hose that came from a little canister near the driver side harness.
d) no idea where it goes...
e) i didnt even have this connected.. didnt think i needed it..
g) there are 2 vaccum hose looking things under that thing
f) no idea...
as you can see this is my first swap and need a little help thanks.!
illios is offline
Old 06-21-2010, 11:38 AM
illios's Avatar
Or could it be from any of the plugs on the engine harness? The one on the back of the mani and the power steering one may be connected wrong
illios is offline
Old 06-21-2010, 12:37 PM
delsolo95's Avatar
follow my diagram i posted earlier geez!!. its just a couple of tubes..
A. FPR
B. IAB (Intake Air Bypass) Purge
E. IAT (Intake Air Temp)
G. IACV( Intake Air Control Valve)
D. Connects to Purge Solenoid
C, B, and A, all connects to the IAB box and Solenoid.. get it
Old 06-21-2010, 12:38 PM
delsolo95's Avatar
if you dont get it just buy a skunk2 manifold
Old 06-21-2010, 01:20 PM
illios's Avatar
i dont have the IAB box tho... nor do i have the IAB purge.. thats my question, can i still get this running without it?
illios is offline
Old 06-21-2010, 01:45 PM
delsolo95's Avatar
im not sure about the IAB since they are like the throttle body plate which opens and close upon acceleration. you could try taking out the diaphram and the plate it connects, since the GSR intake manifold is a three piece, take out the middle piece to eliminate the IAB.
Old 07-11-2021, 08:04 AM
Mvilchis's Avatar
Default Re: High rev on start up *pic*
Thanks!
ever figure out the problem i have exact same problem but with b20 engine
Mvilchis is offline
Old 07-11-2021, 06:39 PM
Hysterically Calm
TomCat39's Avatar
11 year old thread put back to rest.
Like mentioned in the thread, you probably have a vacuum problem somewhere.
TomCat39 is offline
hondale
06-29-2014 02:14 PM
SIDreamer
03-07-2011 12:25 PM
ek_civic96
02-08-2008 12:23 AM
rice a roni
03-31-2005 02:55 PM
wanttorace
09-07-2003 07:38 PM
Quick Reply: High rev on start up
