rattling noise...exhaust? help me figure it out...
Alright, i have a 1997 Honda Civic CX hatch, when i am in certain gears, going certain speeds, i will hear a really annoying rattling sound that sounds like my exhaust rattling bad, but when i press in the clutch, or speed up / shift gears, it seems to go away fro a little bit. Does anyone know what this would be? Anyone know how to fix it? Driving me f*ckin insane! Thanks! =]
BTW i just got this car a little while back, use to have a bomb crx, so this is new territory to me.
Re: rattling noise...exhaust? help me figure it out... (GroundZer0)
do you have a lower tie bar in the rear? Thats what my problem is, my exhaust is always hitting it and makes a terrible nosie as well. What i did was took an old rubber bushing and placed it between my exhaust and my tie bar it makes little to no noise now. your exhaust might also be rubbing against a sway bar or control arm. you can fix it the same way that i said before though.
Re: rattling noise...exhaust? help me figure it out... (hondaeg95)
I dont Have a lower tie bar, no mods as of yet =]... it does seem to be rattling against something, ill have to check it out when its not like -20 outside =[ Any other ideas what it may be? It only seems to do it when in gear..
Modified by GroundZer0 at 2:39 PM 1/18/2004
More than likely it is a heat shield around the converter or on your floor board, incertain gears under cetain loads, you will created just enough vibration to make it go away. You can fix it with a torch or anything that can cut it off.
Re: rattling noise...exhaust? help me figure it out... (reward_1000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reward_1000 »</TD></TR><TR><TD CLASS="quote">More than likely it is a heat shield around the converter or on your floor board, incertain gears under cetain loads, you will created just enough vibration to make it go away. You can fix it with a torch or anything that can cut it off.</TD></TR></TABLE>
What he said, except most of the heatshields will unbolt.
Re: rattling noise...exhaust? help me figure it out... (Revolveu2)
So i should just try taking the heat shields off, should they just unbolt?
Yes, they should just unbolt. I recommend wearing gogles, though, because of the rust. PB B'Laster, too if needed.
AlxSiR7
Suspension & Brakes
01-09-2005 12:45 PM
ramz7887
08-14-2003 07:30 AM
