Ram air, good or bad?
Old 03-06-2002, 05:00 AM
fcuked's Avatar
Default Ram air, good or bad?
I was thinking of making a little homemade mod but not sure if it's worth it. I put my stock airbox in because i don't like having a short ram intake. So anyway, with my resonator removed, would it be a good idea to run some 2.5-3 inch pipe from the air box down to the whole under the left headlight where the foglights go??? Is there already an aftermarket pipe like that made and is it worth it.
BTW, those fog light holes are already cut.
Old 03-06-2002, 05:05 AM
New User
slowerthanu's Avatar
Default Re: Ram air, good or bad? (1.8 HB)
1. Holy crap your Civic is low
2. No, it will provide negligable gains
3. Ram air doesnt exist until over 300 MPH.
Old 03-06-2002, 05:13 AM
fcuked's Avatar
Default Re: Ram air, good or bad? (slowerthanu)
Wouldn't it work sort of like a CAI just better because air is going in the tube?!
Old 03-06-2002, 06:25 AM
Kamin's Avatar
yes but your force feeding the engine air it dosent need/wont use
its pointless.
Old 03-06-2002, 08:23 AM
ZUL8R's Avatar
Default Re: Ram air, good or bad? (KAMiN)
all i got to say is,, when people fabricate ideas for ram air dont **** on them,, they just like working on their car and using their ideas. it cant hurt to have cooler air in the intake. why is everyone so worried about dragging in 100 degree weather if cooler air wont do any thing.......
FREAKS
[Modified by shane89z24, 12:25 PM 3/6/2002]
Old 03-06-2002, 10:16 AM
ImportHatch's Avatar
Default Re: Ram air, good or bad? (shane89z24)
I like the drop on your car. What does your suspension consist of?
Yager-
Old 03-06-2002, 10:22 AM
sushibug's Avatar
thats not true. my friend has a ram air setup in his tacoma... flexy piping sticking from under his bumper. without it he cant beat me, with it... he slowly pulls from my car. i can notice the power difference in switching air filters so why wouldnt cold/ram air not be helpful?
Old 03-06-2002, 10:32 AM
fcuked's Avatar
Default Re: Ram air, good or bad? (sushibug)
That's what i would like to know, good point.
Old 03-06-2002, 10:33 AM
fcuked's Avatar
Default Re: Ram air, good or bad? (ImportHatch)
The drop is 3.8 inches up front and 3.5 at the back on coil over sleeves. Ride is stiff as hell, but it suits my likings.
Old 03-06-2002, 01:45 PM
xtrafastcivic's Avatar
don't make the ram air air tight just leave the hose pointing to the air box so air goes towards it. it will help because cold air is going into the box
and ram air is not ram air untill over 300mph ???? yeah right your on something here try this to prove you wrong buy a iceman headlight ram intake take it down the track and then put on a CAI or regular intake and feels the difference or see the difference on the timeslip
[Modified by XtraFastCRX, 2:47 PM 3/6/2002]
Old 03-06-2002, 01:57 PM
89civicdx's Avatar
Default Re: Ram air, good or bad? (XtraFastCRX)
Is that one passenger headlight cut out for looks?
Old 03-06-2002, 02:34 PM
csufweed's Avatar
Default Re: Ram air, good or bad? (89civicdx)
yeah i believe so... thats nothing but a show integra... all show no go! That hole looks tight! I'm gonna take my headlight out so I can look cool too.
Old 03-06-2002, 02:40 PM
Evil_Wizard's Avatar
If I remember right if you have ram air. At like 60 miles per hour it is equal to 1/2 a pound of boost. Just like on superchargered engines only not need as powerful. It can't hurt anyway because cooling the temperature in the engine bay is very helpful to the motor. Cooler air means more power. If this isn't true why are people always putting bags of ice on there intake manifolds before drag racing?
Old 03-06-2002, 03:31 PM
elmerfudd's Avatar
this is my first post, so please bear with me. I recently added a cold air intake that goes down into the bumper passenger side. I also added a 4-2-1 header. My question stems from this one asked about the ram air. I was thinking of sealing the area where the filter is and then running air ducts hidden inside my bumper into that area to sort of force more air into that area. is this feasable or a waste of time?? I have a 1993 Honda Civic sedan LX with 182,000 miles on it. I drive 55 miles to work everyday in this little car. and can only say how reliable it is. I've done all maintenance work, replace belts, timing belt and water pump. So far I've replaced a blown head gasket and then did the bolt ons. thanks for any input and the good topics posted...
God Bless,
Elmer
[Modified by elmerfudd, 12:31 AM 3/7/2002]
Old 03-06-2002, 03:42 PM
elmerfudd's Avatar
this is my first post, so please bear with me. I recently added a cold air intake that goes down into the bumper passenger side. I also added a 4-2-1 header. My question stems from this one asked about the ram air. I was thinking of sealing the area where the filter is and then running air ducts hidden inside my bumper into that area to sort of force more area into that area. is this feasable or a waste of time?? I have a 1993 Honda Civic sedan LX with 182,000 miles on it. I drive 55 miles to work everyday in this little car. and can only say how reliable it is. I've done all maintenance work, replace belts, timing belt and water pump. So far I've replaced a blown head gasket and then did the bolt ons. thanks for any input and the good topics posted...
God Bless,
Elmer
Old 03-06-2002, 03:44 PM
rota426's Avatar
Default Re: Ram air, good or bad? (elmerfudd)
Sure, more power to you Elmer, try it. By the way what are you smoking 1.8 HB? Please elplain your theories...so far you don't have a leg to stand on. You talk like you're smarter than everyone else, but you don't explain anything.
Old 03-06-2002, 03:45 PM
kefka's Avatar
damn your hatch looks nice.. but ram air is usless...
Old 03-06-2002, 05:01 PM
iceburgslim's Avatar
Default Re: Ram air, good or bad? (madeinjapan)
Elmer, it will help a little to seal it off, but the idea isn't so much as forcing cold air into the intake as it is to seal the intake from under hood heat.
Old 03-06-2002, 06:06 PM
New User
Obviously, nobody gets my sarcasm.
Old 03-06-2002, 06:17 PM
fcuked's Avatar
I will probably do this "setup" over the weekend and I will let you know how it goes. Thanks a lot for all the informative replies guys.
Old 03-06-2002, 07:33 PM
elmerfudd's Avatar
Default Re: Ram air, good or bad? (iceburgslim)
thanks for all the input. I will try and keep all the steps and procedures i go through. I'm also heading for Home depot to get the mesh? spell?? to cover the openings on the front bumper grille. thanks in advance!
God Bless,
Elmer
Old 03-06-2002, 07:37 PM
Pat McGroin's Avatar
i read in one of those manuals, it says 455hp gsr engine, it stated that ram air only works at a certain mph. maybe not 300 but somewhere reasonable.
Old 03-06-2002, 11:21 PM
csufweed's Avatar
Default Re: Ram air, good or bad? (JDM Dasilva)
ok, drive at 80mph and stick your hand out the window... feel the wind hitting your hand pretty hard there??? how bout that air going down a tube into your engine? There you have ram air... only thing is, the ram air is only really useful when you are a WOT cuz all that air can go into the engine.
kinda like the theory behind that electric supercharger... only activates at WOT cuz the throttle plate will allow all that extra air in. Of course I am not saying this product works or not, but the theory is correct...
Old 03-07-2002, 09:27 AM
direct_connect's Avatar
Default Re: Ram air, good or bad? (csufweed)
wouldn't a comptech icebox help? just asking.
Old 03-07-2002, 10:29 AM
Mario's Avatar
Ram air/cold air helps...just ask this guy.
Quick Reply: Ram air, good or bad?
