Radiator Question
Radiator Question
Heres the deal. i have a 97 EK, and i swapped an jdm b16a in it. The question is, which radiator should i install with this. should i use my old one? if so, im having trouble installing it due to the fact that i forgot how i took it out(). On the bottom of the radiator there are 2 ports sticking out, im not sure what to hook up to it. Thanks in advance.
Re: Radiator Question (ReD . EK)
your stock one should be fine for a b16. what do you mean 2 ports? like some kind of line would hook up to it? if thats the case you probably got a automatic radiator. and im sure you know where both the radiator hoses go.
well it was on the car before i swapped to the b16. it looks like hoses connect to it, smaller hoses than the radiator hose on top and bottom
thats an automatice radiator, lines from the automatic transmision run to and from it. just leave it, it your not automatic nothing hooks up to it
Re: Radiator Question (handa)
i guess it is a radiator for an automatic. its okay tho, my turbo is water cooled also so ill just run it thru there. thanks guys.
another question. Which throttle cable do i have to use with this?
yz125rider21
15
01-07-2008 11:42 PM
