Quick! Will this work???? 98 suspension on 93.......
I got a 98 Civic coupe and I need the suspension off of it to put on my 93 Civic Hatch. I need the 2 fron knuckles/hub assembly and same with the rear. Will this 98 suspension work on my hatch?
Re: Quick! Will this work???? 98 suspension on 93....... (JDMatters)
the rear def wont work cause it is setup diff......but the front knuckles/hubs should work
Re: Quick! Will this work???? 98 suspension on 93....... (speedfreek128)
Is there any parts that will interchange in the rear? Like struts maybe? LCA? Anything?
the shocks are the same in the back....I think.....but the LCA are diff and the trailing arm is diff length......get LCA from a 94+ Integ or 92-95 Civic SI/EX they have holes to bolt a sway bar to
you can use front knuckles. Front shock will work. You will need to ghetto fab the brake line mounts, or just be totaly ghetto and let them hang. Upper A arms won't work, and I'm not totaly sure but LCA won't work neither.
You can use rear trailing arms, but can't use LCA or upper control arms. Can't use the shocks unless they are aftermarket (like teins, kyb or illumina).
Re: Quick! Will this work???? 98 suspension on 93....... (ABK)
I have the stock suspension on the EG. But right rear is bent. So I wantd to swap with the EK. With the two can i make one? The suspension on the EK is tokico Illuminas....
do your tokico illuminas fit tight on the ek lca? if u had to use washers to fit em on there then they could probably be swapped over to the eg. eg lca's are wider so the ek shock forks won't fit unless theyre universal.
Re: (nalgas05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nalgas05 »</TD></TR><TR><TD CLASS="quote">do your tokico illuminas fit tight on the ek lca? if u had to use washers to fit em on there then they could probably be swapped over to the eg. eg lca's are wider so the ek shock forks won't fit unless theyre universal.</TD></TR></TABLE>
I havnt tried to swap the rear suspension on cuz i didnt know if it'd work or not....
Re: (nalgas05)
tokico's are universal.
WHORE: JDMCoveralls
Suspension & Brakes
02-20-2006 07:37 PM
mckenzie
Northern California (Sales)
09-14-2005 06:48 PM
